1. shafek113's Avatar
    How much galaxy note 4 battery should last without save power mode? While using Internet and Facebook wattsapp + phone calls??
    07-24-2016 12:13 PM
  2. NexusGirlX's Avatar
    No one here can tell you since how much you use those will affect how long the battery lasts. Screen brightness will also affect the battery.
    07-24-2016 10:23 PM
  3. shafek113's Avatar
    In normal situation
    07-25-2016 06:17 AM
  4. taife32's Avatar
    In normal situation
    Normal situations vary from person to person but looking at your mentioned apps without gaming, you should get comfortably a full day of usage. I'm assuming a total screen on time of about 5 hours here.
    07-25-2016 12:53 PM
  5. shafek113's Avatar
    10 hours.. Is it good? Without gaming... Only phone calls a lot and fb wattsapp
    07-25-2016 02:38 PM
  6. RadeonHD4250's Avatar
    The above posters are correct. We all have different usage patterns, so no one can really tell you what normal use means.
    That being said this is what's normal for me.
    I've been on battery for 30 hours now, with 3 and a half hours of SOT. I have also listened to about 2 hours of music as well. I should hit 4 hours + by the time I hit 0%.
    Screen use was mostly texting, Facebook, Messenger, Instagram and a few pictures. That's it.
    07-25-2016 06:38 PM
  7. NexusGirlX's Avatar
    I get about 2-3 days standby with 2-3 hrs SOT. I have five phones activated so that is why all my phones get about 2-3 days standby with 2-3 hrs SOT.
    07-25-2016 11:31 PM
  8. RadeonHD4250's Avatar
    Which is fantastic when you think about it. That's 48-72 hours of runtime.
    07-26-2016 10:13 AM
  9. NexusGirlX's Avatar
    That it is. On my Note 4/Note Edge, I get these usage times and this is still on the original batteries which are now 1.5 years old. The Note 4 is rooted, the Edge isn't.
    I bought two new batteries for each of these phones a few months back but haven't touched them other then to test them from charging to using once to make sure they were genuine batteries. I just wanted them for backup.
    07-27-2016 06:34 AM
  10. jordyd's Avatar
    I don't think I've ever reached 4 hours of SOT with my N4. It needs charging daily too.
    Still, it's better than my old S4 which died by late afternoon with just 5 minutes of browsing and one call and nothing else! The S4 battery was soo bad.
    07-31-2016 05:21 AM
  1. [Help] Major battery drain for s6 edge plus
    By kenshinous in forum Samsung Galaxy S6 edge+
    Last Post: 08-02-2016, 05:04 PM
  2. Battery is not chrging
    Last Post: 07-24-2016, 12:14 PM
  3. Why is my Galaxy sII battery draining so rapidly
    Last Post: 07-23-2016, 03:39 PM
  4. Major battery drain on S6 edge plus
    Last Post: 07-23-2016, 02:15 PM
