1. Zahum's Avatar
    Hi guys, my air-command suddenly stopped showing-up when I remove S-pen or when I press the button.
    S-pen is fully working tho, I can write, the hover information shows up, and I can use button to highlight text.
    S pen sensor is working, too, as when I remove it, it makes sound.
    The problem somewhere in system, as I can not do anything in air-command tab in option menu (see picture)
    As you can see, the menu is shadow, so it doesn't allows any interaction whatsoever. (Not possible to scroll down, that's it)
    Do you guys know, what to do with that? Possibly if you know how to reinstall drivers or do you think that factory recover would fix it?
    07-26-2016 07:19 PM
  2. taife32's Avatar
    Thanks for ANY reply. Click image for larger version.
Name:	**** me off.jpg
    Just search the net and also wait for an answer in these forums before you do factory reset. Unfortunately my Note's battery is flat at the moment so I can't try to go through the settings and see what shows up on my side.
    07-27-2016 08:23 AM
  3. nahoku's Avatar
    Try starting your phone in Safe mode and then checking your S Pen settings again. If it still doesn't work in safe mode, and being a system app, perhaps a factory reset might have to be done to cure the problem. You should take step now to back up all your data... contacts, photos, vids, etc... as a factory reset will wipe all that out.
    07-27-2016 03:40 PM
  1. a problem seeing the sd card from my laptop
    By reble in forum Samsung Galaxy Tab 2 10.1
    Last Post: 08-18-2016, 03:48 AM
  2. Honda talk button stopped working for AA- please help
    By bosantos in forum Android Auto
    Last Post: 08-15-2016, 11:37 AM
  3. Replies: 7
    Last Post: 07-29-2016, 01:02 PM
  4. Same Problems here!!
    Last Post: 07-26-2016, 06:25 PM
  5. anybody want to help with a lg security error?
    Last Post: 07-26-2016, 05:48 PM
