1. teedubb79's Avatar
    My note 4 is unresponsive can anyone help. It had a full charge and just shut off and won't turn back on. I bought a new battery and it still didnt work so I know its not that. I've tried holding the power button down for a few minutes without the battery, no success. I've tried starting in safe mode still no success. I think its a hardware problem..anyone experience this or can anyone help. Power ic?
    07-27-2016 02:10 PM
  2. SpookDroid's Avatar
    You can try taking it to a Best Buy or a carrier if they have the 'flashing cradle' and see if their equipment can 'see' the phone, but other than that, it's pretty hard to diagnose over messages. You're probably gonna have to take it in to get checked at a repair center. Hopefully it's just the power circuit or the USB one, but it can also be that the motherboard has malfunctioned (and that's pretty expensive to repair/replace).
    07-27-2016 03:02 PM
  3. nahoku's Avatar
    I know you stated this...
    ... but have you tried pressing and holding down the power button (with the battery installed) for about 15 - 30 seconds to see if it would turn on? Also, try pulling the sim and SD card out to see if they have any effect on power up.
    SpookDroid likes this.
    07-27-2016 03:17 PM
  1. Replies: 8
    Last Post: 08-14-2016, 08:29 PM
  2. Note 4 broken what to replace it with
    By monkeypimp in forum Samsung Galaxy Note 4
    Last Post: 08-05-2016, 10:49 AM
  3. Hello! My galaxy s4 verizon is stuck on bootloop. please help !
    By endimerkuri in forum Samsung Galaxy S4
    Last Post: 07-27-2016, 11:01 AM
  4. Replies: 1
    Last Post: 07-27-2016, 10:59 AM
  5. when i dwnld some data my phn show wifi issue so plzz help .
    Last Post: 07-27-2016, 07:19 AM
