1. Arull18's Avatar
    My phone Pin is on but when i lock the phone and switch it on back it says Swipe to unlock.
    In setting says secured with pin
    !?If i click on it and type my password it says wrong password!!! And try again!!please help... i am using GALAXY NOTE4
    07-31-2016 04:39 AM
  2. H3aTeRzz's Avatar
    Hi
    You can try entering recovery and doing a wipe of the Cache Partition, see if that might help.Do you have the S7; similar issue have been reported with that device, after the update to MM. If the cache wipe through recovery won't help, I would suggest the below link to assist you in changing your password. If that won't help, then I'm afraid a factory reset is in order.
    http://forums.androidcentral.com/amb...read-here.html
    Hope this helps!
    Chris
    08-01-2016 05:58 AM
  1. Why my GPS not working recently?
    Last Post: 08-07-2016, 08:05 AM
  2. My Galaxy S3 screen suddenly went black and unresponsive
    Last Post: 07-31-2016, 05:59 AM
  3. Replies: 1
    Last Post: 07-31-2016, 05:57 AM
  4. Phone password wont work and lock!
    Last Post: 07-31-2016, 04:16 AM
  5. How to disable settings security password on Xperia Z?
    Last Post: 07-31-2016, 03:14 AM
