1. Mikeoscar's Avatar
    I have a reduced qwerty keyboard scaled to about 4/5th of the bottom of the screen. Using the settings doesn't change the size I can select qwerty or the 3/4 version. The qwerty is set but doesn't use the full width of the phone ..I can make the keyboard appear to the left or right ....what use is that? t makes it harder to input on such small keys. I have tried a number of suggested solutions..none of which have fixed the issue.
    08-01-2016 10:04 AM
  2. Mikeoscar's Avatar
    My phone is a galaxy note 4 and I've had my phone for a year. Problem just arisen in the past couple of days.
    08-01-2016 10:07 AM
  3. fatyank's Avatar
    Are you using the Samsung built in keyboard or aftermarket? It sounds like you may have done this already. If you're using Samsung keyboard, long press on the microphone icon at the bottom of the keyboard. You should get a popup with six different icons. The far right is keyboard size. Tap on it and it will change the keyboard from large to small or vice versa. The small version can be dragged around (floats) the screen. If you've done this already, try a soft reset (restart) not a factory reset. Many times this clears up problems with any device.
    The Fatyank
    08-01-2016 01:08 PM
  4. BigwhiteUK's Avatar
    Does it look like this?
    Attached Thumbnails Shrunken qwerty keyboard problem-screenshot_2016-08-01-19-15-07.jpg
    08-01-2016 01:15 PM
  5. BigwhiteUK's Avatar
    If so, select and hold the icon next to Sym and various are available.
    08-01-2016 01:17 PM
  6. AXEL314's Avatar
    Like Fatyank explained
    Note 4 910C 6.0.1 | Good Lock UI | Android Central App
    Attached Thumbnails Shrunken qwerty keyboard problem-2016-08-01-15.22.08.jpg
    08-01-2016 05:22 PM
  7. AXEL314's Avatar
    Screen shot not posted ...
    08-01-2016 05:23 PM
  1. Replies: 12
    Last Post: 08-10-2016, 09:05 AM
  2. wierd file transfer problem
    By ethan a in forum Nexus 6P
    Last Post: 08-05-2016, 11:03 AM
  3. pixtocam problems, anyone else use it?
    By Rich215 in forum Android Apps
    Last Post: 08-01-2016, 01:32 PM
  4. Replies: 1
    Last Post: 08-01-2016, 01:23 PM
  5. Tablet problem
    By stormtrooper_9 in forum More Samsung Tablets
    Last Post: 08-01-2016, 12:29 PM
