1. martyjaward's Avatar
    Here is an odd one...
    I am away in Greece at the moment and my Note 4 had a massive hissy fit. Wouldn't connect to any networks & basically wouldn't do much at all. In the end it crashed and restarted itself.
    Now the problem. The phone now has its home time zone as Athens (GMT +3) , but I need it to be British Summer time (GMT +1). Is there a way to manually correct the home time zone so that the roaming time is correct for greece. I have tried all the combinations of manually setting the time, but it won't set right.
    08-02-2016 02:22 AM
  2. quaranta4gat's Avatar
    In the time and date settings uncheck both the automatic time and the automatic time zone options. Then you can manually select GMT + 1 and the time you want. Shouldn't change by itself anymore.
    08-02-2016 04:07 AM
  1. Tag Heuer Connected faces problem
    Last Post: 09-08-2016, 04:51 PM
  2. Samsung S4 i9500 screen problem
    By TheUnknownKid in forum Samsung Galaxy S4
    Last Post: 08-06-2016, 06:03 PM
  3. Replies: 0
    Last Post: 08-02-2016, 12:06 AM
  4. Email Icon On Home Screen
    Last Post: 08-01-2016, 10:09 PM
  5. Replies: 2
    Last Post: 08-01-2016, 01:56 PM
