1. Whirlwindpro's Avatar
    Just started doing this Friday after some of my apps updated & google was one of the apps that did update. Only reboots when someone in my contacts calls me & I have the audio ON. If I have it on vibrate it works normally, If I have the audio on everything else works perfectly except when someone calls me it rings once & then reboots the phone. Caller shows on display for a second, phone reboots but after the phone reboots there is no record of the call in the call log either. When it's on vibrate the phone works same as before. Verizon is my carrier.
    08-22-2016 12:23 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! That's a strange bug. Does it persist after wiping the cache partition? https://support.t-mobile.com/docs/DOC-28932. Or in Safe Mode? Galaxy Note 4 Safe Mode: What you need to know | Android Central
    08-22-2016 02:45 PM
  3. Whirlwindpro's Avatar
    It does the same thing when it's in safe mode. Wiping the cache...same results. Works perfectly when on vibrate mode though??? So weird!!! And to make it even stranger is it only does it when cel phone numbers in my contacts call...when it's a land line it works fine as well.
    08-22-2016 04:23 PM
  4. dabombcra's Avatar
    This is the first that I have heard of this issue. Go into Best buy and speak With one of the Samsung reps. Show them what it is doing. Maybe they Can fix it
    B. Diddy likes this.
    08-22-2016 09:59 PM
  5. B. Diddy's Avatar
    This suggests a problem with the firmware or hardware. You could try reinstalling the firmware using Samsung Smart Switch (SmartSwitch: Install & update or replace firmware), Kies (http://forums.androidcentral.com/amb...sung-kies.html), or Odin (http://forums.androidcentral.com/amb...interface.html). Or you could ask the folks at Best Buy to reflash the firmware as well.
    08-23-2016 07:34 PM
  1. I cannot preview pdf attachments in my email
    Last Post: 08-22-2016, 12:25 PM
  2. Simple Search and Contact question
    Last Post: 08-22-2016, 12:19 PM
  3. how do i disable select sign key off my android 5
    Last Post: 08-22-2016, 12:12 PM
  4. Why has my call logs automatically deleted?
    Last Post: 08-22-2016, 12:06 PM
