1. umby75fg's Avatar
    Hello, I have got my Note4 SM-N910F with Emotion Kernel with root access and latest MM stock firmware (ITV).
    Sometimes I notice an overheating and lags and probably it depends on kswapd0 process (or Android system) that I saw it overloads the cpu and the phone becomes very slow.
    Do you know how can I test properly and I can fix the issue?
    Droidful likes this.
    09-27-2016 05:35 PM
  2. Droidful's Avatar
    I just found this to be my issue as well, same file. Did u find an answer yet?
    10-06-2016 11:46 AM
  3. umby75fg's Avatar
    Excuse for my late response. I did searchings about this issue and it seems has related on some kernel.
    I read somewhere that trying different kernels the people fixed the issue.
    I seem the someone solved tge ussuee through Semaphore Kernel 2.1.1 but in my case I can't change the kernel because I'm interesting on kernel for Zerolemon battery and when I restart the phone the issue disappeares.
    I hope I could help you..
    10-09-2016 05:48 AM
  4. Droidful's Avatar
    I started disabling apps, I think I found the cuplrit. After all of the disabling I recalibrated my battery. Seems to be better both this is just the first whole day since the downsize. Also I installed an app I had on my s4. (Green power pro). It will limit the syncs and turn off data and WiFi when asleep if a white listed app is not using.
    umby75fg likes this.
    10-09-2016 11:32 AM
  5. umby75fg's Avatar
    That process seems something about I/O writing/reading.
    I don't think you will fix the issue.
    When I read on some forums people said that the issue was disappeared for one day and after reappeared again..
    Only changing the kernel I read more people fixed this annoying working process..
    10-09-2016 02:24 PM
  6. Droidful's Avatar
    my kernel listed above.
    I'm looking at batteries and chargers now. Came here to see what's better generic or or OEM refurbished and caught your post.
    10-12-2016 10:15 PM
  1. When is the relaunch of the Note 7 in Canada?
    By Sailor Webber in forum Samsung Galaxy Note 7
    Last Post: 09-29-2016, 09:17 AM
  2. Battery max charge is 87% after marshmallow update, why?
    Last Post: 09-28-2016, 12:29 AM
  3. charging the Galaxy S6
    Last Post: 09-27-2016, 07:14 PM
  4. How to fix the Samsung headphones vietnam
    Last Post: 09-27-2016, 06:36 PM
  5. why is my samsung tablet draining in a half hour of use
    Last Post: 09-27-2016, 05:47 PM
