1. Chris Oliva's Avatar
    Every time I call a conference number and attempt to provide conference code, my Note 4 is sending multiple digits for each entry.
    Example: a code of '1041' is returning error message of 11004411. I've already changed from short to long DTMF in settings and it doesn't help
    HELP!!! Or this phone is going to the heap.
    09-29-2016 12:50 PM
  2. Rukbat's Avatar
    Call another phone and press buttons while you listen to the other phone. If it's sending double tones, or there's a break in the middle of a tone, the phone needs to be repaired. If not, the particular conference number you're using may not be designed to work with packetized data. (If it gets a tone in two packets, it may see it as that tone being sent twice. There's a similar problem with fax on a VoIP phone - fax is designed for copper, not digital.)
    09-29-2016 03:37 PM
  1. What is the glass portion on the rear used for?
    By choclab1 in forum Google Pixel & Pixel XL
    Last Post: 10-11-2016, 07:44 AM
  2. What is this icon?
    By chuka101 in forum Ask a Question
    Last Post: 09-29-2016, 05:14 PM
  3. Can I fix Marshmallow issues without factory reset?
    Last Post: 09-29-2016, 04:19 PM
  4. Replacement Note 7's are Safe to Fly
    By SpookDroid in forum Samsung Galaxy Note 7
    Last Post: 09-29-2016, 12:47 PM
  5. Replies: 1
    Last Post: 09-29-2016, 12:40 PM
