1. umby75fg's Avatar
    Hi, I have got SM-N910F with an IBestwin large battery (10000mhA) installed.
    I flashed a Emotion kernel for Zerolemon (10000mhA) on my latest stock firmware (MM) and I made battery calibration many times but I notice a fast discharge from 100% to 82% and then the discharging turns to quite slow as should be I guess..
    I used Battery Calibration app and Advanced Battery Calibration but I'm still noticing the same problem.
    Do you know how can I fix it?
    10-02-2016 03:30 AM
  2. gietek's Avatar
    Did you wipe cache partition?
    umby75fg likes this.
    10-02-2016 06:23 AM
  3. TwitchyPuppy's Avatar
    Wiping the cach partition would do the job, as cellphone batteries don't require calibration, nowadays.
    10-02-2016 08:31 AM
  4. umby75fg's Avatar
    Thanks both.
    I'll try it and a new battery calibration included.
    I know that for kernel replacing it's advisable to do a battery calibration..
    Edit: I still have the same issue.
    I did the wipe dalvik cache and system.
    I hope that I wiped right because in twrp recovery I found many boxes and to avoid some problem I checked only Dalvik and System.
    Did I wipe it right?
    10-03-2016 03:05 AM
  1. Replies: 39
    Last Post: 10-13-2016, 03:04 PM
  2. Replies: 2
    Last Post: 10-02-2016, 11:50 AM
  3. Replies: 2
    Last Post: 10-02-2016, 11:48 AM
  4. Why does my phone lose battery when plugged in?
    By LordeShiate in forum Ask a Question
    Last Post: 10-02-2016, 03:16 AM
  5. Replies: 0
    Last Post: 10-02-2016, 12:11 AM
