1. Kilroy672's Avatar
    I'm highly considering in getting a used Note 4 to replace my Note 7. A few things I was wondering. Is the 4 capable of having off screen off memo? I know the 5 and 7 has it. And can the 4 use the first version of VR? This far fetched but thought I'd ask.
    AXEL314 likes this.
    10-16-2016 09:21 AM
  2. pdalper's Avatar
    The Note 4 can do "off screen" notes. That came with Marshmallow The other I do not know..
    10-16-2016 10:37 AM
  3. AXEL314's Avatar
    Yep as mentioned off screen memo was introduced in MM, and yes, the original Gear VR is compatible with the Note 4.
    10-16-2016 03:14 PM
  4. ChetManley762's Avatar
    You can use a note 4 with the consumer edition of Gear VR also. You need to grind out the corners with a Dremel tool so the N4 fits.
    Consumer edition is way cheaper than the original Gear VR. I bought one used for $60 vs $200+ for the N4 compatible version.
    10-16-2016 05:25 PM
  1. Interesting - any reports of burning Note 7s in the past week?
    By jmnesq in forum Samsung Galaxy Note 7
    Last Post: 11-03-2016, 02:33 PM
  2. 4.1 crashing on galaxy note 10
    By Shawn Patton1 in forum Samsung Galaxy Note 10.1
    Last Post: 10-18-2016, 05:45 AM
  3. Note 4 to s7 edge will I miss
    By magichoward in forum Samsung Galaxy S7 edge
    Last Post: 10-16-2016, 02:00 PM
  4. Replies: 0
    Last Post: 10-16-2016, 05:56 AM
  5. How do I change the outline of my fonts on Samsung Galaxy note 4
    By Happyclick52 in forum Samsung Galaxy Note 4
    Last Post: 10-16-2016, 02:54 AM
