1. lainiest's Avatar
    Has anyone tried to see if their freebie Note 7 256GB sd card will fit into the Note 4?
    If I have to downgrade, I am still keeping my Note4!
    10-21-2016 06:48 PM
  2. anon(10057381)'s Avatar
    I used a pair of very sharp scissors and a fine nail file... the card fits just fine.
    lainiest likes this.
    10-21-2016 06:57 PM
  3. TwitchyPuppy's Avatar
    The Note 4 has a MicroSD reader so I don't see why it wouldn't!
    10-21-2016 07:53 PM
  4. rushmore's Avatar
    I took the 256gb card from the Note 7 and straight into Note 4. Works great.
    cinnamin likes this.
    10-21-2016 10:17 PM
  5. Js2000ster's Avatar
    Yes, I am using the consolation gift 256GB card in my note 4 with zero problems.
    10-22-2016 04:23 AM
  6. Tsepz_GP's Avatar
    MicroSD cards have never changed physical size, so yes, it will fit.
    SIM Cards on the other hand have had physical size change.
    10-22-2016 04:46 AM
  7. Kilroy672's Avatar
    I just got my note 4 today. Put in my 256 GB card in to see if it works. It made it lag real slow. At one point it shut off and would not turn back on whatsoever. I tried everything and nothing until I took out the SD card and it powerd up. Could that be the reason it shut off? It's fine now, but if I have to I'll put my 64 GB card in the meantime.
    10-27-2016 11:36 PM
  8. Tsepz_GP's Avatar
    That is very weird, there may be a file(s) in the MicroSD that it couldn't index and thats why it lagged and shut off.
    10-29-2016 12:09 PM
  9. Andre de Guerin's Avatar
    Thanks re. the index issue. On the flip side people may be listing their 256GB uSDs for sale soon.
    Its not like Samsung want them back and besides which most people use the card for personal data
    so there would be significant issues sending them back with the cards in.
    A useful tip, a write test with H2testW followed by a format takes less than 40 minutes on USB2 and lower still on a USB3 card adaptor.
    This permanently wipes any slack space on a given card or full wipe if formatted first, best to use one of the certified SDXC units
    as most older laptops and card readers pre 2014 do not support cards this big due to a very stupid buffer overflow problem on the controllers.
    I had problems with the 128GB when it first got installed, had to fiddle with it to make it work.
    Pretty sure FAT32Format did the trick followed by reformatting it in the phone.
    01-30-2017 01:34 AM
  1. Looks like T-Mobile might be getting the Pixel
    By gabbott in forum Google Pixel & Pixel XL
    Last Post: 10-22-2016, 01:17 AM
  2. How to hide one app from other app?
    Last Post: 10-21-2016, 06:47 PM
  3. is anyone out there decided to keep the note 7?
    Last Post: 10-21-2016, 06:06 PM
  4. Pixel XL back in stock on Google Store
    By Brandwin in forum Google Pixel & Pixel XL
  5. Want a black or silver one *today* and live in the bay area? PM me.
    By quietlybrilliant in forum Google Pixel & Pixel XL
    Last Post: 10-21-2016, 05:59 PM
