1. Jeremy Foster's Avatar
    Will factory reset help?
    10-23-2016 03:46 PM
  2. nahoku's Avatar
    Depends on what the problem is. The Note 4 forum has a lot of battery threads. You might visit it and read the posts.
    10-23-2016 04:13 PM
  3. Gbsa's Avatar
    My note 4 was draining battery really fast, getting very warm. Battery stats showed android os and system were the ones draining battery. Did a factory reset, opted to manually set up the phone instead of installing apps from my last back up. Now the phone is running well again. No overhearing, decent battery life. 5 - 6 hours sot usually lasts 12 - 14 hours.
    10-27-2016 06:45 AM
  4. B. Diddy's Avatar
    Welcome to Android Central! Moved to the Note 4 forum.
    It would help to see some battery stats. Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/gen...d-central.html
    You might have to install a 3rd party battery monitor, like GSam Battery Monitor, to get the Cell Signal Strength graph.
    10-27-2016 10:24 AM
  1. Battery charging speeds
    By Clayton Short in forum Google Pixel & Pixel XL
    Last Post: 11-11-2016, 06:55 AM
  2. Replies: 0
    Last Post: 10-23-2016, 02:50 PM
  3. Why is my battery life draining so fast?
    Last Post: 10-23-2016, 02:41 PM
  4. Samsung Galaxy Note 4 Error. Since Update To Marshmallow.
    Last Post: 10-23-2016, 01:09 PM
  5. Battery life?
    By AKFL3TCH3R in forum Google Pixel & Pixel XL
    Last Post: 10-23-2016, 12:48 PM
