1. Porkchopexpress1969's Avatar
    Has anyone used or heard of :
    TechOrbits 3220mAh Battery pack for Samsung Galaxy Note 4
    https://www.amazon.com/Samsung-TechO...cUvbUpU5518904
    Amazon has decent reviews but havent seen much reviews after that. Just wondering if anyone has heard or used this one before.
    10-24-2016 09:37 AM
  2. Rukbat's Avatar
    Anker (on Amazon) also has some reputation. https://www.amazon.com/Capable-Anker...cUvbUpU5519658 for one, https://www.amazon.com/Anker-3220mAh...cUvbUpU5519658 for 2 and a charger.
    Rowlette likes this.
    10-24-2016 02:04 PM
  3. mbhq's Avatar
    I picked up the Anker Note 4 package on Amazon that includes a slow charger with 2 batteries. I did this when my Note 4 was new and I rotate all three. I can't tell which is the original as far as longevity.
    It works out great for me. I switch out the spare I carry in my backpack at the end of the day, placing the freshly charged one in in my bag, and the one in my phone then goes in the charger.
    I guess I'd prefer to use OEM batteries, but at the time the cost difference was prohibitive all in, and Anker has a good reputation.
    huntnyc likes this.
    10-24-2016 05:22 PM
  4. nahoku's Avatar
    Also, AC Store very often have the batteries on sale for $16.95. Their support is very good too!
    huntnyc likes this.
    10-24-2016 07:10 PM
  5. NexusGirlX's Avatar
    To be honest never heard of them before. In addition looking at the reviews on Amazon it sounds sketchy as many state the battery would no longer hold a good charge after a month or two of use. Either way I'd stick with Samsung OEM (couple options listed below) or a known brand such as Anker. They may cost a little more but I think the old axiom "You get what you pay for..." still holds true!
    1. AC's own ShopAndroid: Samsung 3220mAh Standard Battery for Galaxy Note 4 - Android Batteries - ShopAndroid
    These are genuine Samsung (bought in bulk). They do not come with the plastic carry case. I bought 2 back in March and so far they're still working great.
    2. Verizon: Samsung Standard Battery for Samsung Galaxy Note 4 - Verizon Wireless
    Picked up 2 of these as insurance when I wasn't sure if the ones from ShopAndroid were genuine or not. These do come with the plastic carry case.
    AC Forums added a affiliate link to the Verizon link so it will not open on my computer just so you know.
    10-24-2016 08:25 PM
  6. nahoku's Avatar
    Hmmm, funny, I don't have a problem opening the Verizon link on my PC... running Firefox. Here's the straight link... copy and paste if you must... less the quote marks.
    "https://www.verizonwireless.com/accessories/standard-battery-for-samsung-galaxy-note-4/"
    edited again!
    10-24-2016 09:12 PM
  7. NexusGirlX's Avatar
    I use an adblocker, that's why. That link don't work for me either.
    10-24-2016 09:15 PM
  8. nahoku's Avatar
    I use an adblocker too. I edited the link info again.
    And..... again.... this one should work... copy and paste, no quotes
    10-24-2016 09:20 PM
  9. i2mmobile's Avatar
    I went with a couple of these. My friend has this on his note 4 and he gets a bit over 2 day..
    https://www.amazon.com/gp/product/B0...cUvbUpU5529685
    10-28-2016 03:47 AM
  10. ermitico's Avatar
    I bought the Anker battery based on good reviews but had a pretty bad experience. The phone kept heating up excessively for long periods even after turning it off and on. The battery longevity was poorer than my 1.5 year old original battery. When I swapped in my original Samsung battery the phone was fine, no over heating and it still lasted longer than the Anker.
    I ended up buying two original Samsung batteries with the external charger combo. No more battery life worries as I rotate across 3 batteries.
    11-15-2016 05:50 PM
  1. Can we stop calling the LG V20 a replacement phone?
    By Jeremiah Bonds in forum LG V20
    Last Post: 10-25-2016, 01:13 PM
  2. Replies: 2
    Last Post: 10-24-2016, 02:05 PM
  3. Battery Life
    By qfnol31 in forum Google Pixel & Pixel XL
    Last Post: 10-23-2016, 11:23 PM
  4. Does the Samsung Galaxy S7 have battery exploding issues too?
    By Meowstic in forum Samsung Galaxy S7
    Last Post: 10-23-2016, 11:07 PM
  5. Replies: 3
    Last Post: 10-23-2016, 09:38 PM
