1. AC Question's Avatar
    When I try to open the screen on my Galaxy note 4 by pressing the power button,it takes around 3-5 seconds to respond.
    So is there any way to fix that?
    You should know that I have Marshmallow 6.0.1 installed.
    11-25-2016 12:44 AM
  2. Javier P's Avatar
    Mod note. Thread moved to the Note 4 forum for more visibility.
    11-25-2016 06:54 AM
  3. nahoku's Avatar
    MM is relatively slow from what I saw before I downgraded my spare Note 4 to LL... but it's not that slow. Have you tried starting your phone in Safe mode? Might be an app causing the issue, or it might be syncing, or even a corrupt file on the SD card. You might try removing the SD to see if it helps.
    11-25-2016 06:37 PM
  4. IAmSixNine's Avatar
    Is your phone running warm by any chance? poor battery life?
    11-29-2016 04:44 PM
  1. I lost my camera icon gionee s5.1 how should i recover it ?
    Last Post: 11-25-2016, 06:55 AM
  2. Replies: 1
    Last Post: 11-25-2016, 12:47 AM
  3. Whats wrong with my volume?!
    Last Post: 11-25-2016, 12:40 AM
  4. Replies: 0
    Last Post: 11-25-2016, 12:34 AM
  5. Looking to buy phone with no carrier
    Last Post: 11-24-2016, 11:50 PM
