1. sandra_17's Avatar
    Considering getting one for my husband who has my old Note 4. I have the 2016 for my Note 5 (and previous Note 7). I see there was the "Innovator" edition previously for the N4, but it's been discontinued. Has anyone used the 2015 edition successfully with their N4?
    TIA
    11-25-2016 05:45 PM
  2. AXEL314's Avatar
    Sadly no as stated on Samsung's site:
    http://forums.androidcentral.com/e?l...token=lgx_c5yD
    An alternative would be to pick up one of many available VR headsets. I personally use the Habor headset as my VR viewer (a few times a week I might add) and paired with the Gamesir bluetooth controller, my setup provides great amount of entertainment.
    If you do go with another VR headset, try and get one with a magnet input so it's compatible with Cardboard apps out of the box. If not, no biggie, as some controllers (such as the Gamesir I mentioned) has a built in mouse mode, which in Android, translates to a touchscreen input (that's what the magnet on VR headsets do). With that said, good luck with finding a VR solution!
    sandra_17 likes this.
    11-26-2016 06:37 AM
  3. sandra_17's Avatar
    Thanks so much for all the great info. Now.....decisions, decisions!
    11-26-2016 07:51 AM
  4. Paradroid01's Avatar
    The new Gear VR for the S7/S7 Edge etc. does work.
    11-26-2016 10:06 AM
  1. Replies: 4
    Last Post: 03-09-2017, 09:00 AM
  2. Replies: 23
    Last Post: 11-29-2016, 03:10 PM
  3. Why does Device Manger detect my phone only through WiFi?
    Last Post: 11-26-2016, 04:47 PM
  4. Pull down screen doesn't work
    By amyf27 in forum Samsung Galaxy S7 edge
    Last Post: 11-25-2016, 05:44 PM
  5. Replies: 1
    Last Post: 11-25-2016, 05:22 PM
