I've just bought a new Note 4, under settings and system it says it's the n910F version, but cpu-z says the bootloader is N910SKSU2COL1. If I boot it in safe mode (home button + volume up + power), it's says
Android system recovery <3e>
LMY47X.N910SKSU2C0J4
recovery mode (home button + volume down + power) gives me the warning in korean language then states product name as SM-N910S
Also, and what bothers me the most is that I have a huge battery drain on the phone. I tried wiping the cache and hard resetting the fone for the 4th time now, still getting a massive battery drain doing basically nothing. I've just lost 15% in less than 40 minutes from a 100% charge. My guess is that the phone was "badly" updated from KitKat to Lollipop (KNOX warranty void is on 1, and i can't get the OTA update for Marshmallow).
I would like to update it to 6.0.1 (or again to 5.1.1 myself) to see it that fixes the problem, but I am not sure how to do it since my case is a little bit "particular" if i may say so.
I come from an iphone, so any help would be extremely appreciated, I am completely lost.
Thanks
Thanks
