1. cbs1507's Avatar
    I have a note 4 for verizon that has no signal. Does anybody know any solutions?
    11-28-2016 04:34 PM
  2. Laura Knotek's Avatar
    Hi and welcome to AndroidCentral.
    Does this happen everywhere or just in a certain location?
    You might want to call Verizon and ask them if they are servicing any towers. Otherwise try getting a new SIM from Verizon.
    11-28-2016 05:03 PM
  3. B. Diddy's Avatar
    Is the phone a Verizon variant, or did you get it unlocked from somewhere else?
    11-28-2016 07:08 PM
  4. IAmSixNine's Avatar
    was it recently repaired or damaged?
    11-29-2016 04:00 PM
  5. cbs1507's Avatar
    Thanks for your response. Well I don't have a sim card or Verizon atm. It happens all the time. But I haven't taken it out of the house.
    12-09-2016 10:49 AM
  6. cbs1507's Avatar
    Verizon branded.
    12-09-2016 10:49 AM
  7. cbs1507's Avatar
    Not to my knowledge. It doesn't appear to have been opened and I've had it for over a year but could never use it for anything but a tablet.
    12-09-2016 10:51 AM
  8. natehoy's Avatar
    If you need Verizon signal for a Verizon-branded Note 4, your best bet is to take it into a Verizon store and have them look at it. They should be able to get it fixed up and running without any problems. I bet even if it is out of warranty they could do something for you if you are looking to buy service from them.
    Since you've had it for over a year, it's obviously out of warranty, but it should be pretty easily fixed as long as the hardware wasn't defective when you bought it.
    12-09-2016 11:36 AM
  9. B. Diddy's Avatar
    Hey, just wondering -- do you have a Note 4 or a Note 4 Edge? I noticed that you've posted about both (http://forums.androidcentral.com/mor...ml#post5583597), in addition to a problematic S5. Did all of them suddenly go kaplooey?
    12-10-2016 02:43 AM
  10. ninjaunmatched's Avatar
    Check your network settings. You can get that if some setting is set wrong. Like if its set to GSM Only or something like that.
    12-10-2016 02:46 AM
  1. No smoking sign in place of signal
    By cbs1507 in forum Samsung Galaxy S5
    Last Post: 01-26-2017, 04:15 PM
  2. Certified Safe Car chargers for note 5
    By mwake4goten in forum Samsung Galaxy Note 5
    Last Post: 12-01-2016, 10:18 PM
  3. I somehow switched my notification on my note 5
    By lisalisa13 in forum Samsung Galaxy Note 5
    Last Post: 11-30-2016, 12:26 PM
  4. Help with upgrading my note 10.1 2012 edition
    Last Post: 11-28-2016, 05:20 PM
  5. Replies: 0
    Last Post: 11-28-2016, 02:58 PM
