1. Hasibuzzaman Tonmoy's Avatar
    This problem occurred before too. After dropping it from my hand, the display went pure black/blank. Removed the battery, tried to turn it on. Holding down the power button causes the LED to light up(just as it does while turning on), vibrates a little bit but that's it. Nothing more . No sound, nothing.
    I tried :
    *Accessing Recovery & Download mode
    *Hold down the power button for a minute with the battery removed
    *Called my number but it says turned off
    *Charge
    *Connect to PC
    Note : This happened before but automatically got fixed after a few hours. But this time, it's the same after a day.
    Took it to a service centre but they claimed that the display's broken and I've to pay 'bout $200 to replace it. But I really don't think display's the problem here cuz as I mentioned, it happened before and the phone's not working.
    02-01-2017 11:26 PM
  2. justinxfan's Avatar
    Yeah sounds like your lcd is screwed. It may not look like it but your entire screen has been knocked out and needs to be replaced.
    02-01-2017 11:55 PM
  3. AXEL314's Avatar
    Sounds like this second drop may have knocked a connector loose or something.
    02-02-2017 12:29 AM
  1. Help updating my galaxy tab 2 10.1
    Last Post: 02-01-2017, 11:11 PM
  2. LG K7 process com.google.process.gapps has stopped working
    Last Post: 02-01-2017, 10:50 PM
  3. Replies: 0
    Last Post: 02-01-2017, 10:35 PM
  4. Replies: 0
    Last Post: 02-01-2017, 10:12 PM
  5. Why are some of my apps stuck on the loading screen?
    Last Post: 02-01-2017, 09:56 PM
