1. Khaled Mahmoud1's Avatar
    Hi everybody
    I have a problem with my note 4 n910c on android 6
    The device takes time more than usual to charge. I used to charge it from 0 -100 % in about 90 minutes.
    But lately it takes more than 2 hours to charge. From 0 to 80% it takes about one hour and this is normal but from 80-100% it takes more than an hour. Does anyone have the same problem and how can I solve it?
    I tried discharging the battery totally and charging it while device is off and the problem still exists. I tried also clearing the cache partion and nothing changed.
    02-15-2017 04:06 PM
  2. Morty2264's Avatar
    Welcome to the forums! How long have you had your Note 4? While it is normal for older phones to encounter battery/charging hiccups, the problem you mention seems to maybe point to a battery that is closer to the end of its lifespan.
    Are you using the charger/cable that came with your phone? Have you tried others to ensure that the problem indeed lies with the battery?
    02-15-2017 05:42 PM
  3. Khaled Mahmoud1's Avatar
    It's only less than a year and I'm using the original charger and unfortunately I have no other fast charger to try it.
    Morty2264 likes this.
    02-16-2017 09:31 AM
  4. Morty2264's Avatar
    If you're using the original charger and cable that came with it, there is a chance it could be that the battery is wearing out. Bring it to your carrier's store and see if their fast chargers (I'm sure they have a couple lying around) give you a similar result when your phone is plugged in at 80%. Let us know what happens!
    02-16-2017 03:39 PM
  5. armin80's Avatar
    Hi everybody
    Just change the charger cable
    02-17-2017 09:37 PM
  1. Why are my outgoing emails listed as queued in my outbox
    Last Post: 02-04-2020, 12:21 AM
  2. my Samsung galaxy tab 3 running slow why
    Last Post: 09-10-2017, 02:51 PM
  3. Replies: 2
    Last Post: 06-29-2017, 12:33 PM
  4. Replies: 1
    Last Post: 02-15-2017, 06:45 PM
  5. I have Samsung J7. Are my photos on jpeg format?
    Last Post: 02-15-2017, 04:21 PM
