1. armin80's Avatar
    Dear all,
    I have note 4 but I am facing issues with the SD card ,once inseted in the phone it's start freezing, restart and hangs.
    Sometimes work on sd card without any issues just for 1 hour and when I play song after 15 seconds the song stopped playing .
    I have tried 3 SD cards brand new San disk and Toshiba exceria 16 and 32 GB and still facing same issue .need your help forum.
    02-17-2017 09:29 PM
  2. B. Diddy's Avatar
    Do you keep putting the same data on each card? If so, then one of those files might be corrupt (or malicious).
    02-17-2017 10:20 PM
  3. armin80's Avatar
    But the same SD cards working on my note 2 without any issue
    02-18-2017 05:29 AM
  4. B. Diddy's Avatar
    The same cards work with the same data saved to them?
    02-18-2017 03:02 PM
  5. armin80's Avatar
    Yes
    02-18-2017 08:56 PM
  6. B. Diddy's Avatar
    It might be due to some app that's on your Note 4 that isn't on the Note 2. Unfortunately, it's difficult to know for sure.
    armin80 likes this.
    02-18-2017 11:29 PM
  7. IAmSixNine's Avatar
    If you can run the note 4 with no SD card, then put in an SD card and get issues, i would try to boot phone with a card, then use the phone to wipe/format the card and reboot and see if that solves the issue.
    02-20-2017 10:51 AM
  8. armin80's Avatar
    Before 2 days I revived update around 450 mb and this solve the issue. Till now my sd card work without any issues.
    03-05-2017 10:02 AM
  1. Replies: 3
    Last Post: 03-03-2017, 01:13 PM
  2. HELLP HTC M9 Charing issues
    By David Allen13 in forum HTC One M9
    Last Post: 02-17-2017, 10:22 PM
  3. Note 5 and Gear VR, not impressed
    By anderdea in forum Samsung Galaxy Note 5
    Last Post: 02-17-2017, 09:32 PM
  4. I can't change my location on my Google weather card
    Last Post: 02-17-2017, 07:03 PM
  5. Unknown sim card
    By Maynebrittany0308 in forum Ask a Question
    Last Post: 02-17-2017, 05:58 PM
