1. AC Question's Avatar
    So my Galaxy Note 4 has been having problems lately, and has been randomly restarting even though it was working fine right before the restart. I didn't think too much of it, so I just continued normal usage until a couple of hours ago when it restarted into recover mode.
    It was my first time using android recovery mode so to be safe, I just selected the reboot option, but the phone failed to reboot even after around 30 minutes. I took out the battery and tried to turn it on again, and it went straight back into recovery booting.
    I tried to wipe cache partition, mount /system, power off (and back on again, but that just led back to recovery mode), and reboot to bootloader, but it just gives me a black screen without actually rebooting.
    Is there anything I can do to save my phone? I have a ton of important data that isn't backed up in it, so I really don't want to factory reset unless really necessary (I don't even know if that will fix the problem anyways).
    03-18-2017 02:01 PM
  2. ChuckWithAZ3v's Avatar
    I have a note edge (very similar to note 4) and once I was having a bootloop issue with it. Getting to the maintenance boot menu helped me out.
    -With the phone off, press and hold the volume down and power keys
    -Continue holding after the first vibration until you feel a second vibration.
    -You should be in maintenance boot mode.
    when I was having my bootloop issue, I selected USB Debugging Mode and my phone booted normally. Hopefully one of these options helps your phone to boot up so you can make a backup of all your files.
    Robert Tarver likes this.
    03-18-2017 04:39 PM
  1. Came from a Galaxy S7 Edge...
    By whiteshadow001 in forum Moto Z Force
    Last Post: 03-20-2017, 06:07 PM
  2. How to stop web texts on a galaxy S7
    By AC Question in forum Samsung Galaxy S7
    Last Post: 03-19-2017, 02:30 PM
  3. How do I disable amber alert still alerting after five days
  4. How to launch installed app from service over lock screen.
    Last Post: 03-18-2017, 11:08 PM
  5. What apps or software is he using
    Last Post: 03-18-2017, 11:07 PM
