1. Dankees's Avatar
    I've had my phone since the day it was released. I baby it.
    Recently, it's been locking up, freezing, restarting, won't turn on unless the battery is pulled, etc.
    I did two hard resets and it's still happening.
    Why???
    Please give me suggestions to fix my phone. Please!
    03-22-2017 11:11 PM
  2. TwitchyPuppy's Avatar
    I'd try a factory reset, to eliminate the software factor.
    If it fails to solve the issue, you definitely should get it checked.
    Dankees likes this.
    03-23-2017 06:43 AM
  3. Dankees's Avatar
    Thanks.
    Ugh!
    03-23-2017 06:47 AM
  4. KeepItReal's Avatar
    You may try another battery. You can order one from Amazon fairly reasonable. Also, unmount your SD Card, as it may be corrupted. When I perform a Factory Reset, I use the "powered off" method for all phones. I also don't restore my information from Google during the setup prompts. This way I am not bringing something back that may be causing a problem. Please backup everything!
    https://forums.androidcentral.com/e?...token=i8X_VPjo
    If, after replacing battery, unmounting/removing the SD Card, and then the "powered off" Factory Reset and the phone still has issues, hopefully you have insurance, and can get a replacement.
    Rowlette and Dankees like this.
    03-23-2017 07:10 AM
  5. armin80's Avatar
    Remove SD card
    Dankees likes this.
    03-26-2017 03:27 PM
  6. Dankees's Avatar
    The SD Card could have gone bad?
    Does it need to be replaced? Or, remove it and just put it back in? Remove it and start the phone without it in and then put it back in and restart?
    03-26-2017 03:31 PM
  7. al3azim's Avatar
    I do not believe it is the SD card. This seems to be a common problem with the NOTE 4 suffering from MMC failure after almost crossing the 2 year mark. I am experiencing the same issue myself with mine and nothing will really fix this other than replacing the motherboard. A temporary fix is an app called wakelock from the play store. This will help with the freezing and rebooting but of course it does not repair the issue but is also will darin the battery a bit quicker as it leaves the CPU on in the background. This is the only fix that has worked for me and others suffering from this issue. Here is a link to the app and you can read from the reviews and comments about other experiencing the same issues you are - https://play.google.com/store/apps/d...u.thedarken.wl
    03-27-2017 11:30 AM
  8. Rowlette's Avatar
    I guess you are enforcing next move to a Pixel XL, my experience and fanboy for Samsung phones has been dwindling to a point that enough is enough.
    03-27-2017 11:54 AM
  9. frellingfrakker's Avatar
    Mine was doing some of the same things. I bought a replacement battery a couple of weeks ago and no issues since then.
    03-27-2017 02:39 PM
  1. my headphone jeck..
    Last Post: 03-24-2017, 01:52 AM
  2. Replies: 1
    Last Post: 03-22-2017, 11:21 PM
  3. How do i get my hands set to work on my phone
    Last Post: 03-22-2017, 11:04 PM
  4. my headphone jeck..
    Last Post: 03-22-2017, 10:59 PM
  5. why does google keep stop recording my voice after 5 - 10 seconds
    By stephen13470 in forum Android 7.0 Nougat
    Last Post: 03-22-2017, 10:50 PM
