1. AC Question's Avatar
    Hello, so I have thismproblem with my note 4 that drives me crazy because that for no reason whenerver i plug my phone into the charger, the screen turns on like if i got a message or something, but instead theres nothing there.
    Maybe little easier to understand:
    When the phone is unplugged from the charger, the screen only turns on when i get a notification or message and i am ok with that.
    But when i am charging my note 4, the screen turn on without having a notification or message, exept for the "39% charged" notification. Is there a way to remove this or? Otherwise i might go back to my old note 2.
    Sorry if you can't underatand properly but its late and ill rbabily look here tommorow
    04-02-2017 05:51 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! It's normal for the screen to turn on when you first connect the phone to the charger. But the screen should still timeout and go to sleep after the interval you set. If it's remaining on, go to Settings>Developer Options​ and make sure Keep Awake isn't turned on.
    04-03-2017 11:50 PM
  1. Replies: 1
    Last Post: 04-03-2017, 11:55 PM
  2. Very high touch lag on brand new LG K4 120E
    By antoniu200 in forum More LG Phones
    Last Post: 04-03-2017, 11:54 PM
  3. Replies: 1
    Last Post: 04-03-2017, 11:51 PM
  4. My mobile battery doesn't charge
    Last Post: 04-02-2017, 11:24 PM
  5. Reseting input language error on Huawei p9
    By AC Question in forum Huawei P9 & P9 Plus
    Last Post: 04-02-2017, 11:21 PM
