1. AC Question's Avatar
    Anyone has any idea how to make it work.?
    05-04-2017 11:24 AM
  2. indysteve9's Avatar
    Do you have the phone set for power saving. I forget which power saving setting it is but if you select it, it will not display the two buttons you mentioned.
    05-05-2017 01:06 PM
  3. anon(634141)'s Avatar
    Go to settings, display, touch key light duration and make sure it's not set to off.
    05-05-2017 01:52 PM
  1. Small space between the glass screen and the meral housing
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 05-06-2017, 11:21 AM
  2. How to unlock my A9 pro Pattern Lock Without Loss Data
    Last Post: 05-04-2017, 02:25 PM
  3. How do I use okay Google without unlocking the screen?
    Last Post: 05-04-2017, 11:14 AM
  4. Replies: 1
    Last Post: 05-04-2017, 10:35 AM
  5. Replies: 0
    Last Post: 05-04-2017, 10:34 AM
