1. AC Question's Avatar
    I am used to using the home+power buttons method to get a screencapture on the Samsung phones which I have owned. But recently after an application installation made the permissions a little messy, as well as the functioning of a few other applications.
    I decided to totally uninstall all applications and reinstall them from Googleplay again. Now that it has been done, it seems like all is working but when I try to do a screencapture, I get the "Unfortunately, System UI has stopped" error. I've tried to change and use the screen swipe method but I still get the error.
    Is something missing? Do I have to reinstall something from Samsung again? I didn't (and couldn't) uninstall system and pre-installed applications, so I don't think I removed any necessary items. What do I need to make sure is available and running for the screencapture system to work?
    05-07-2017 06:42 AM
  2. lucianus_luciferus's Avatar
    maybe some app is disabled...
    05-07-2017 08:29 AM
  1. Digital clock on lockscreen
    By AC Question in forum Samsung Galaxy S8 & S8+
    Last Post: 05-07-2017, 08:55 AM
  2. Why is my phone trippin
    By Ayden alcorn-payne in forum Ask a Question
    Last Post: 05-07-2017, 08:44 AM
  3. Google Play Services missing after system upgrade
    Last Post: 05-07-2017, 06:49 AM
  4. Wifi not turning on after software update
    Last Post: 05-07-2017, 06:41 AM
  5. Digital clock on lockscreen
    Last Post: 05-07-2017, 06:10 AM
