1. Jerigorn's Avatar
    So after almost 2 years on my Note 4 I bought a new battery to give it some life. The 'Power Bear' battery worked great for a couple months, but then started draining very quickly and would take 8 hours to charge completely. I did not make any changes to OS or apps. So I chucked it up to a ****ty battery. I then purchased another brand - now discharge was somewhat better, but still the 8+ hours to charge. I have tried factory resets, but no change. Ideas at this point? Buy a third battery or trash the phone? Im currently using a S5 and my plan was to get the S8+. I love that phone, but im a Note fan a hearr. At this point I'm thinking of waiting to see what the a note 8 has to offer, but using this S5 is painful. Thanks in advance.
    05-25-2017 03:23 PM
  2. pkcable's Avatar
    Sounds to me like it's more than the battery at this point. Could be an issue on the motherboard or another component. If it were me I would replace the phone.
    05-25-2017 03:40 PM
  3. SpookDroid's Avatar
    Unless you get an original battery, you can't really compare times (or unless you get it from a reputable manufacturer who has met all compatibility specs with the device for charging and REAL charge capacity).
    Also, if you're a Note fan, the Note 7 IS being re-released and will certainly be cheaper than a Note 8 if budget is a concern.
    05-25-2017 03:51 PM
  4. krauster's Avatar
    Maybe a cable problem? Maybe a charger problem?
    TechNut79 likes this.
    05-26-2017 09:43 AM
  5. TechNut79's Avatar
    Definitely could be a charging cable problem. I had this issue before. I replaced the cable and it started working fine.
    05-26-2017 11:27 AM
  1. Why is my Note 5 Notification Muting Intermittently?
    Last Post: 12-06-2017, 07:39 PM
  2. New Note 8 leak video shows front glass...
    By jamezr in forum Samsung Galaxy Note 8
    Last Post: 05-28-2017, 10:13 PM
  3. Replies: 6
    Last Post: 05-27-2017, 10:30 AM
  4. Wireless charging issues?
    By jimbo1mcm in forum Samsung Galaxy S8 & S8+
    Last Post: 05-26-2017, 10:14 AM
  5. lose text messages on att note 5 7.0
    Last Post: 05-25-2017, 04:46 PM
