1. Note4TheBest4U's Avatar
    First, I cannot live without WA. So uninstalling is NOT an option, please.
    254
    GSAM monitor screenshot is attached. WA version is latest - 2.17.254.
    From a 10000mAH (the stock battery is about 3000mAH), WA alone has consumed half of 7000 (about 35000mAH) in about 12 hours!!!!!
    Something is wrong with that WA or it is accessing to try something that is draining the battery.
    Already tried resetting the phone and reinstalled the App, no change.
    07-22-2017 09:37 PM
  2. Javier P's Avatar
    Welcome to the forums. You could try changing the WhatsApp backup settings just in case something got stuck in there. Open WhatsApp - three dots top right - settings - chats - chat backup - select 'only when I tap backup’ and then restart the phone. Charge your phone after this, use it normally for a day and see if the same problem persists.
    07-23-2017 07:49 AM
  3. Note4TheBest4U's Avatar
    Thanks Javier. That is one of the few things I have not tried. Doing it now and will report it in a day or two.
    07-23-2017 08:35 AM
  4. Javier P's Avatar
    Another thought. Just as test go to whatsapp settings - data usage and select 'no media' for the three options under auto-download. Do you usually receive lots of media files?
    07-23-2017 08:56 AM
  5. Note4TheBest4U's Avatar
    Yes, All 3 (Mobile Data, Wifi, Roaming) were previously set to No Media. I receive some media but due to WA limitation where you cannot store it to SD card, I set it to No Media long ago.
    07-23-2017 10:11 AM
  1. Where can I find the stock ROM for a p10 lite?
    By MarkoNikolic2 in forum Huawei P10 & P10 Plus
    Last Post: 12-25-2017, 06:23 PM
  2. Traded galaxy s8+ for the g6
    By swagglepuff in forum LG G6
    Last Post: 08-06-2017, 08:00 PM
  3. How good is the audio on the U11, really?
    By wynand32 in forum HTC U11
    Last Post: 07-31-2017, 05:14 PM
  4. Will The S8 price drop much when the Note 8 comes out?
    By Kendal1L in forum Samsung Galaxy S8 & S8+
    Last Post: 07-24-2017, 09:17 AM
  5. Replies: 1
    Last Post: 07-22-2017, 09:15 PM
