1. AC Question's Avatar
    I have been using my phone for years but just recently (after being deployed to Jordan) my Verizon Note 4 N910V has been refreshing all my apps every 20-30 seconds. For example, on YouTube if I am watching a video the screen will blink as if loading a page again on chrome then will leave me at the play button as if I haven't watched the video yet. The phone sometimes even resets apps to them just being opened or if I am scrolling down a list brings me back to the top. I have tried redownloading the apps, factory reseting, redownloading the update for the os, cashe clearing, and going into safe mode and nothing has repaired my issue. If someone knows how to fix this please inform me.
    07-24-2017 06:58 AM
  2. natehoy's Avatar
    Are you running any memory cleaners/optimizers, task killers, or the like?
    If you are, I'd start by uninstalling those.
    07-24-2017 12:55 PM
  3. L0n3N1nja's Avatar
    Might seem odd but does it happen with airplane mode on? Might be some kind of a connection issue causing other problems.
    07-24-2017 02:15 PM
  4. Larry_F's Avatar
    I can't offer any suggestions, but here is a thread where others described the same problem. There is no solution in that thread either, but you can see what others have tried.
    https://forums.androidcentral.com/sa...efreshing.html
    Larry
    07-24-2017 02:31 PM
  5. Controser's Avatar
    Hey I was the original poster of this thread. I have still been having the issue and have found no solution anywhere so far. While I do not have a optimizer installed, I have not tried airplane mode since I factory reset so I will get back with you on that one. I also tried a antiviral scan and found no issues.
    07-28-2017 05:42 AM
  1. Sprint Galaxy S8 Bixby Killing Google Fixed
    By Targatheory in forum Samsung Galaxy S8 & S8+
    Last Post: 08-16-2017, 12:11 PM
  2. Replies: 0
    Last Post: 07-24-2017, 05:01 AM
  3. Replies: 0
    Last Post: 07-24-2017, 03:34 AM
  4. Replies: 1
  5. How can i send songs to otherphones through whatsapp
    Last Post: 07-24-2017, 03:12 AM
