Samsung Note 4 can't place calls from Bluetooth headset while phone locked
I had an issue where I could no longer place calls from my phone via my Bluetooth headset while my phone was locked. I did it previously before I reformatted my phone.
I discovered I had "S Voice" as my new voice dialing after I reformatted.
In order to make calls while your phone is locked, you must MAKE GOOGLE "G" YOUR DEFAULT APPLICATION.
Samsung forces you to unlock the phone. Good luck.
Re: Samsung Note 4 can't place calls from Bluetooth headset while phone locked
Moved from the Galaxy Note forum (for the original Note phone) to the Note 4 forum.
