1. Charleneqii's Avatar
    As soon as i plug out my phone from the charger it loses signal and the immediately dies or reboot having than 0%, if i have no wifi network or mobile network data my phone lasts a few minutes, I bought a new battery about twee weeks ago so that is definitely not the problem, and also wiped my phone twice now stil doesnt reasolve anything
    09-27-2017 07:15 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Sounds like some other hardware problem, like the motherboard. Bring it to a repair shop.
    09-27-2017 10:46 AM
  3. natehoy's Avatar
    Did you get a good quality battery? Do you know anyone else with a Note 4 that you could possibly swap batteries out with them and see if a battery that works in theirs fails in yours?
    If that doesn't work, then I'd take it to a repair shop as B. Diddy suggests.
    B. Diddy likes this.
    09-29-2017 08:59 AM
  1. Ringtones for Mobile Phones
    By peaksel in forum Android Apps
    Last Post: 04-26-2018, 03:05 AM
  2. Replies: 4
    Last Post: 09-28-2017, 12:27 AM
  3. Transferring apps to another phone
    By ckfilmstar in forum Axon 7 & Axon 7 mini
    Last Post: 09-27-2017, 05:14 PM
  4. Samsung J3 and signal failure
    By AC Question in forum Samsung Galaxy J Series
    Last Post: 09-26-2017, 06:52 PM
  5. i reset my samsung galaxy j3 my phone will not except new goggle passwod
    By forevrnu17 in forum Samsung Galaxy J Series
    Last Post: 09-26-2017, 06:17 PM
