1. Bernice Stewart's Avatar
    I've been trying to get rid of LG TV remote on my note 4. I'm not finding an app in manage apps or app listing nor a widget. there doesn't seem to be any place on my phone to get rid of it. So what's the solution to get it off my phone!
    03-12-2018 12:04 PM
  2. Rukbat's Avatar
    That sounds as if you have a shortcut but not an app. Long-press the app and see if you get a 'remove' choice or, depending on the launcher you're using, look to see (when you're long-pressing it) if there's a trash can at the top center of the page. If there is, drag it there.
    03-12-2018 01:49 PM
  1. How to I adjust my volume on my galaxy S8+
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 03-12-2018, 05:08 PM
  2. Replies: 0
    Last Post: 03-12-2018, 11:29 AM
  3. found in bfs phone files. anyone know what it means
    By assles in forum Ask a Question
    Last Post: 03-12-2018, 11:20 AM
  4. Can I exercise Bixby then get Samsung Voice-to-text back?
    By Cephyr13 in forum Ask a Question
    Last Post: 03-12-2018, 11:06 AM
