1. Jeremy Guiao's Avatar
    A couple months ago i was able to use my mobile data just fine then out of nowhere it said that i only have 1g data. I completely restarted my phone and it still didnt work what do i do?
    04-19-2018 07:01 PM
  2. Rukbat's Avatar
    The more you download/install, the less you have left. Restarting doesn't change that, deleting/uninstalling does.
    04-20-2018 04:36 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! Are you saying that you now have a monthly data limit of 1 GB, whereas before, you had a bigger data plan?
    04-21-2018 12:45 AM
  1. Elixer 2 Widget Mobile Signal Strength issue
    Last Post: 04-21-2018, 10:38 AM
  2. Why are there no smaller phones. Jeez us.
    By sdmf in forum Samsung Galaxy S9 & S9+
    Last Post: 04-21-2018, 10:08 AM
  3. Expansion file not moved to extSD
    By BobAchgill in forum Android Apps
    Last Post: 04-20-2018, 03:54 PM
  4. What is this symbol?
    By skidmark in forum Samsung Galaxy S7 Active
    Last Post: 04-20-2018, 11:47 AM
  5. My Nexus 5x front camera isn't working
    By Android Central Question in forum Nexus 5X
    Last Post: 04-19-2018, 08:01 PM
