- Nov 14, 2018
- 1
- 0
- 0
Had it for about 3-4 years no problems, then yesterday it just froze and then I took out battery put it back in and it was stuck in boot, tried two batteries no luck. Then decided to to boot in recovery and factory reset...it then worked! Except now within 10 mins the phone will freeze, vibrate twice and then restart, same problem on both batteries. I didn't restore any apps so can't be a software issue. And this Partial Wake lock thing doesn't help either still the same thing happens
Is there a fix? Should I just sell the phone for scrap and buy another?
Phone isn't and never was rooted.
Thanks.
Thanks.
