1. datum9's Avatar
    The batteries between a 'regular' Note 4 and Note 4 Duos are different and a regular ZeroLemon that works in a standard Note 4 won't work in the Duos model.
    What extended batteries will work in the DUOS Note 4 model?
    Note 4 Dual SM-N9100 = EB-BN916BBC (3000 mAh)
    Note 4 N910U = EB-BN910BBE (3220 mAh)
    05-07-2019 08:48 AM
  2. Rukbat's Avatar
    If the battery fits, and the contacts match (they should), use a Note 4 extended battery.
    05-08-2019 04:43 PM
  3. datum9's Avatar
    I already tried fitting in a standard battery from the "standard" Note 4 into the DUOS version. It does not fit, it's different, a bit slimmer.
    I am sure an extended battery would not fit because the piece that goes inside the phone where the standard capacity battery fits is exactly the same as the OEM battery, it's has a larger piece on top of it.
    On that matter, post #2 answers the question in this thread. They are different batteries. That is the problem.
    https://forums.androidcentral.com/ba...ml#post6542450
    05-10-2019 10:43 AM
  4. datum9's Avatar
    There is a pic of the DUOS model in this thread but hard to tell how it's different than the 'standard' Note 4. It's the only pic I could find.
    https://forum.xda-developers.com/not...5#post79501041
    05-10-2019 11:18 AM
  1. Replies: 8
    Last Post: 05-09-2019, 06:26 PM
  2. Galaxy s9+ Dual sim always on
    By Android Central Question in forum Samsung Galaxy S9 & S9+
    Last Post: 05-07-2019, 02:47 AM
  3. Galaxy s9+ Dual sim always on
