jlost
Trusted Member
I would like for the screen to get bigger. I just hope they don't drop micro sd and removable battery like they did with the S6. I can upgrade until the note 6 comes out anyway but still. If the next 2 iterations dissapont then I'll probably head back to the iPhone. Miss the seamless integration that I once had with my macbook and other apple devices.
You can or cannot upgrade tell the Note 6 comes out? I'm not sure if the Note 5 will have the removable battery or sd card, but it seems that they are going the way of Crapple and sealing the phone up. It's sad but it will still be a great phone.
