3gb of RAM and the same camera as the S6
If true this would not be a flagship device at all.
The source link below has found a document from US carrier Sprint that details the specs of the Galaxy Note 5 (with model number SM-N920P) and the device shows 32GB of storage with the word “yes” beside “external memory slot.” In addition, the microSD card slot will leave room for up to 128GB of expandable storage. Coupled with the 32GB of internal storage, users can expect at least 160GBs of storage should they purchase a microSD card with the maximum storage allotted.
Sprint Galaxy Note 5 specs include microSD card slot; has Samsung had a change of heart? - SamMobile
A lot of people on other carriers will probably be unhappy if this isnt a universal thing
I'll place my bet right here: The Note will NOT have sd card support, but the Edge Plus will, as it will use the Qualcomm 808, and the Note will use the Exynos and new memory.
I hope I'm wrong. Really, really do. But I doubt it.
I highly doubt the Edge Plus will have SD card support, since its just a bigger S6 Edge. Now I'm not saying the Note 5 will have an SD Card, but out of the 2 devices, I think the Note 5 will be the likely one to have a SD card slot
The note edge might just do it for me.
definitely a deal breaker for me. If it loses either the removable batter, sd card, or s-pen, i'm buying a iphone 6+. Android user experience is already bad enough for me, especially with samsung's physical buttons. btw, I'm a tech guy (mobile developer), i just dont see any business users using android in general.
No SD on either device
