smooth4lyfe
Trusted Member
Re: Will you upgrade to Note 5 if it doesn't have SD slot?
I understand you are trying to make a point, but its not as bad as you are making it out to be
1. Google Photos is unlimited cloud storage (which is already a plus)
2. Overnight uploading is not a bad thing, its the same thing as backing up your big files to a external Hard Drive overnight, which is what I do and pretty common if you are backing up large amounts of files
3. The photos will pause if the connection breaks, and will automatically resume once its back up
4. Set it up so that when you take a pic, it goes on your SD Card, but automatically will save on the cloud as an extra backup...do no wait till you get 8GB of photos before you do a bulk upload
5. You need to get a better hotel if its offering you that speed. I have heard of no hotel with such a low speed, unless you are connected to someone else's wifi
And just so you know, if your SD card crashes, gets misplaced, or damages, say goodbye to your photos. I HIGHLY recommend you back them up to a cloud service or external HD
I don't think you understand the crux of the problem. If I have 8 GB of data and I need to upload it, but my connection speed from a hotel with crappy wifi is only 0.1 Mbps, it would take 10,666 minutes to upload. Even if the upload speed was 1 Mbps it would still take 1,066 minutes.
My point is, when dealing with large amounts of data (photos/videos) and you have no access to fast wifi, you NEED an SD card for the additional storage. Uploading to the cloud so you can clear out storage is just not feasible, I shouldn't have to wait overnight to make sure my photos upload. What if the connection breaks, or a photo fails to upload? What if I run out of storage during the middle of the day? Having the additional storage right with my device gives me the ability to keep on trucking without having to worry about uploading or having enough storage space.
