smooth4lyfe
Trusted Member
Here is more proof that the Sprint Document was FALSE....
Verizon’s Galaxy Note 5 gets listed on benchmark with Exynos 7420 CPU, 4GB of RAM - SamMobile
So happy its 4GB of ram and not 3GB
Yea, but not happy it's the same processor as the S6. I held off on the S6 because I figured the Note 5 would be better in almost every way but it looks like it's just going to be internally the same as the S6 on a bigger screen. :/
The negative though being this means the Sprint place holder had zero intel, since both the chipset and ram size were wrong. This by default means the sd slot would be bogus info too. The case render... not even worth a serious thought right now IMO.
Sadly the same sources who apparently correctly reported 4GB ram are also the more persistent there is no sd slot or replaceable battery. Giant S6 with pen. Great consolation my Note 4 still rocks
And I can replace the battery if needed to keep it so for another year Try THAT Note 5. Patooey!
You would think they would learn from the bad sales of the S6. GNOTE5 needs the MicroSD.Big thread!
1. Android treats ram (IMO poor design decision) as a giant stack register, so fills it almost all up. If they put 4GB, you will end up with about the same free ram as 3GB. The only way this will not happen is if you do not have enough apps installed to fill the ram up.
2. I would say a 10% chance of a replaceable battery
3. About 50% chance of an sd card
4. The media latched on to a Sprint place holder and a rendered case photo for the sd slot- very iffy. Nice if true though
5. Samsung must operate in an opaque bubble if they think they can get rid of both features and not take a big sales hit with the Note.
Sent from my SM-N910V using Tapatalk
This is LG's big chance to gain share since they have a Note competitor coming out in October with 5.8" 1440p display and 32gB/64GB choices with replaceable battery and SD slot. You can guarantee LG is hoping Samsung continues their near suicidal Apple wannabe fetish.
True but with Android (unlike other OS) that is a good thing. That means more things can be loaded into the RAM for quicker access... So more RAM means more things opening faster and such. The free RAM isn't an issue.
Not necessarily. The increase in RAM is more so to keep pace with upgrades in OS, Apps, skins, HD gaming, features etc. As these things become more RAM intensive (use more to operate) having more is better for a smoother experience combined with increased processing power. More things probably won't be loaded into RAM if everything else increases in the amount needed to operate.
From my experience, the case renders are pretty much accurate in terms of how the phone will actually look. It was the same with the S5 and S6 case renders that were shown before the phone actually released and ended up looking the same. I bet that the case manufacturers get a dummy phone of the actual device before release, which is how they are able to make the case designs and renders and release them before the phone actually comes out
hopefully if not im switching to the iphone 6s plus..... since samsung want to be like them and limit what you can do
There was absolutely nothing wrong and actually everything right with the design language of the Note 4 and Galaxy Alpha. There was no reason to S6 the S6 and Note 5. There's nothing wrong moving over to Apple either, as the iPhone is a good balance.Bye then. If those features matter so much to you, why not go for something like the LG G4 or HTC One M9? While the M9 doesn't have a removable battery, both have SD Card slots.
That has been a problem with the, "Well I'll just go to Apple instead of Samsung then." I don't understand that. You clearly have other options and act like it's an either/or issue. Saying it on a forum isn't going to make Samsung change a phone.
Being completely honest, it's only with the design of the S6 and likely N5 that I have come back around to being interested in Samsung. I got tired of the bad and buggy build quality in the S, S2, and S3. My sister got an S4 and I wasn't impressed. I got an HTC One M7. Fantastic build quality. I loved it. After that I got the G3 and, though it has a removable battery and SD Card slot, I've never needed it.
Don't get me wrong, I understand that some people need certain features, but why not move to a phone that has them instead of complaining about it online?
