cocoparkjacky
Active member
Re: Will you buy the Note 5 if it doesn't have a SD card and/or removable battery?
i will not thinking about it ,i am waiting for galaxy 6 plus
No.Many leak photos show a phone that looks like a bigger GS6.
So it might not have a removable battery or SD card.
Will you still get it?
The Note 5 will likely be a fine device for folks that do not care about additional storage, or the likely near four digit price point of the 128gb model. Doing the math in that regard, the Note 4 with 128gb micro sd would be closer to $200 cheaper. Factor that with 32gb more storage and swappable battery, the Note 4 appears a more compelling and practical case for a lot of folks..... .
I'm sure everyone who said I'm not getting it because..... will.
via the Android Central App With S6 Edge
Is there a forum or thread where people are discussing note 5 alternatives? That moto x pure thing is 5.7" I've read it does and doesn't have microSD, AND it's half the price of the note 5... even cheaper than the note 4.
You get what you pay for, but it appears it's a bump up from my note 3. Op2 has no microSD, but has the USB-C and is a better cpu than the moto.
Everyone would adapt and forget about SD cards except in their fond memories. At least that's what I think.I wonder what will most of yall do if in the future all phones from this point on removed the SD card and removable battery... Would yall never upgrade?
Sent from my Samsung Galaxy S6!
I would be holding on to my GNOTE4 like some people hold on to the flip phone!I wonder what will most of yall do if in the future all phones from this point on removed the SD card and removable battery... Would yall never upgrade?
I would buy the Note 5 if I wasn't looking at the new Moto X Pure Edition, I can get 64GB and microSD which is fine. But I like the Note and the fingerprint sensor. But, I don't want to drop $1k out of pocket on a phone when I can spend a lot less.
My original thoughts were, "no replaceable battery AND no microSD option...no deal." But, with the revelation that there will be a microSD option and the sealed battery should be enough to get a moderately heavy user through the day, I'll probably do the upgrade. However, I'm still not buying into the glass back. It'll add weight to any already large phone. The current back of the Note 4 is thin plastic, yet it's durable and doesn't add weight. That would have been fine with me for the Note 5. That said, looks like I'll do the upgrade...especially since my Gear S will only work with Samsung devices. And I do love my Gear S.
Not sure where you heard there will be a SD option, but there won't be.
The latest leaks seem to point out that there will be. It will be on the slide out tray for the SIM at the top of the phone. The latest photos seem to back that up. We'll just have to wait and see for sure.
The Moto X does have an SD card, is 5.7, and starts at 400 dollars with a price bump of 50 per storage bump. The storage is 16/32/64.
The S6 Edge also has a slide out tray on the top of the phone, and it does not have an SD Card slot
Unless you are saying there are 2 trays (one on the side AND one at the top), I will need the pics of the renders showing that
He may be saying it will be like the Moto X Style (or Pure Edition in the US) where the SIM tray is also an SD card tray.
Hmmm, I have not seen any leak that even points to the possibility of that. Did I miss something?
No -- he is just saying the SIM slot for the Note 5 looks bigger so he is hoping for that.
