1. itony's Avatar
    After recently getting the Note 4 last month to bide my time until the Note 5, I realized that my phone had ABSOLUTELY HORRID GPS connection. It was able to detect satellites but near impossible to use because it wouldn't lock in.
    After much research it turned out that although some people didn't have any problems, this was a very common occurrence. And guess what? Same problem with the Note 3.
    My fix was opening up the phone and adjusting the connection points which I would absolutely not be doing with a brand new phone.
    The point I'm just trying to bring up is that I'm surprised that this hasn't really been brought up. The last two generations have the same problem and I will not be getting the next one until I know for a fact that this has been solved!
    mscolwhite likes this.
    07-21-2015 01:42 PM
  2. dpham00's Avatar
    Didn't have a problem on my note4 or note3
    skatergirl and msndrstood like this.
    07-21-2015 02:02 PM
  3. Kwaii64's Avatar
    The galaxy s4 depending on the custom Rom had a lot of GPS problems. My note 4 has flawless GPS on the stock rom(rooted of course) but there are custom roms out there for the note 4 that specify what's working and what isn't. With the amazing gps and extremely fast data I'm stuck on stock.
    Now if straight out the box and even with some rebooting you still have gps problems I'm guessing that store has a bad batch. I'd recommend going to another store of the same carrier for the same phone.
    07-21-2015 04:21 PM
  4. Almeuit's Avatar
    It sounds like you may have a dud / need to exchange if you can. I haven't had GPS issues on any of my previous Samsung devices (including the Note 4).
    msndrstood likes this.
    07-21-2015 05:01 PM
  5. itony's Avatar
    i wish i could switch it lol unfortunately it was used off ebay and after i opened up the phone and adjusted it, the gps has been terrific.
    I'm not complaining this is more of a potential PSA to potential note 5-ers. Just wanted to put it out there and see what the consensus was here.
    I read a lot of people say their phones are fine but a simple google search will show a lot of threads about this problem
    ex: GPS close to unusable :/ | Samsung Galaxy Note 4 | XDA Forums
    http://forums.androidcentral.com/sam...s-problem.html
    thanks
    07-21-2015 06:26 PM
  6. Gunny94's Avatar
    I have no issue what so ever with my GPS, In fact it's way better than my Note 3 (which had some minor issues on tracking upcoming roads for some reason)
    07-23-2015 05:40 AM
  7. srinathp1988's Avatar
    interesting
    Interesting
    02-12-2016 09:37 PM
  8. Not Quite Right's Avatar
    If it makes you feel better my Note 5's GPS works fine. ...
    02-13-2016 07:26 AM
  1. What is wrong with my Blu Studio G Smartphone?
    By emilykmask in forum General Help and How To
    Last Post: 07-24-2015, 07:59 AM
  2. Wifi calling not working at all
    By killa2dahead in forum HTC One M9
    Last Post: 07-23-2015, 09:09 AM
  3. Replies: 2
    Last Post: 07-21-2015, 03:45 PM
  4. Replies: 1
    Last Post: 07-21-2015, 01:20 PM
  5. Replies: 0
    Last Post: 07-21-2015, 01:10 PM
