1. Steve Bruno2's Avatar
    One feature I heard (rumor) is that Note 5 will have wireless charging. is this true?
    08-05-2015 11:50 AM
  2. JayWill's Avatar
    It hasn't been confirmed, but I'd say it's very very likely. The Note 5 is looking like it'll be a bigger Galaxy S6 with a stylus (think iPhone 6 Plus sans stylus), so I'd bet it'll include all the same features as its smaller sibling.
    08-05-2015 12:04 PM
  3. 21stNow's Avatar
    I think that it will, but my issue is that it will probably be PMA rather than Qi (my preferred method).
    08-05-2015 01:15 PM
  4. smooth4lyfe's Avatar
    It will most likely be both in the Note 5.
    The Galaxy S6 uses both wireless standards. I'm sure the Note 5 will be the same
    08-05-2015 01:17 PM
  5. 21stNow's Avatar
    Thanks, that's good to know. What threw me off was that the charging pad at AT&T seemed to be PMA only. Maybe it's just the version that they sell, as I see that the version that Samsung sells is a Qi charger.
    08-05-2015 01:37 PM
  6. beh's Avatar
    If it follows the S6 it will have both standards of wireless charging.
    08-05-2015 10:09 PM
  7. sup3r1or's Avatar
    It will! It will have same wireless charging capabilities as Galaxy S6
    08-06-2015 06:24 AM
  8. dpham00's Avatar
    Considering it is basically a larger s6 with a stylus, I would suspect that it would.
    08-06-2015 11:32 AM
  9. Madscotsman's Avatar
    yes it will, 100%
    08-06-2015 12:38 PM
  10. mclarryjr's Avatar
    Will my older Qi chargers that I used on my Galaxy Nexus work with the Note?
    08-06-2015 01:30 PM
  11. Almeuit's Avatar
    It should as long as the Note 5 works with Qi chargers (it should since the S6 did).
    mclarryjr likes this.
    08-06-2015 01:43 PM
  12. sup3r1or's Avatar
    Yes it will, it has almost all supported Wireless charging options.
    I have tried charging S6 edge on my Nokia wireless charger from Lumia 930 and it worked.
    mclarryjr and 21stNow like this.
    08-07-2015 02:33 AM
  1. Replies: 3
    Last Post: 08-06-2015, 10:30 PM
  2. Replies: 1
    Last Post: 08-06-2015, 02:31 AM
  3. Lg g2 verizon takes long time to charge.
    By chrismer90 in forum LG G2 mini
    Last Post: 08-05-2015, 09:57 AM
  4. Replies: 0
    Last Post: 08-05-2015, 07:40 AM
  5. Nexus 7 not charging
    Last Post: 08-05-2015, 05:28 AM
