verks
If I keep it I'll get this one. I love the UAG products.
Sent from one of my many phones using Tapatalk
//images.tapatalk-cdn.com/15/08/13/3c0420fc713ddc9d1d8bd11a783e0ad9.jpg
I will be getting the Samsung S-view case and flip case. Hopefully both will be compatible with wireless charging.
I really like this one and will probably get it. Can't go wrong with Scarlet Red and White since I'm a Husker fan.
That big glass design needs something to absorb shock. Harder cases with just short drops will likely result in the same cracking issues as the S6 and iPhone. Worse considering more surface area than S6. Kinetic and static energy knows no mercy with glass.
What are the chances that Incipio will make an Offgrid Case for the Note 5/S6 Edge+ with an extra battery and microsd slot like they did for the regular S6/s6 edge? If samsung was smart they would make their own case with expandable storage and battery. Tha way everyone wins.
I used Otterbox because of likely hood of damage to the device due to my profession. When I got my Note 3, Otter was slightly back ordered so I picked up a Seidio case and holster. Otterbox makes a better "Rugged" holster, but I think Seidio makes a slightly better case, and they are available sooner.
Both cases are available at release this time and both are quality cases. I went with the Seidio however because it's slightly thinner and they put the hard shell on the outside, Otterbox does it hard shell inside and soft outside. Just a preference for me.
Its by Obliq and you can get it in a whole bunch of different colors. Sorry I thought I included the manufacture by I cause I was wrongWhat kind of case is this?
