felloffthetruck
Trusted Member
Good grip on sides and back?
Sent from my SAMSUNG-SM-N920A using Tapatalk
Yes, very good.
Otterbox has always held themselves in very high regard.Nice. I really want my Otterbox, but they are too high right now.
I'll tell you what, the Tumi case is turning out to be one of my favorite Note 5 cases. It just feels, fits and functions 100% perfect on the Galaxy Note 5. Just started using it this afternoon and I'm amazed at the feel and fit of this case. It adds no bulk at all to the phone, just wish it had port covers (got on my port plugs though).
View attachment 200692View attachment 200693View attachment 200694View attachment 200695View attachment 200698View attachment 200699View attachment 200700
Their QC is not very good though. Either you get a good case, or you get a very sh**y case. A few times I've had to return the cases they were so poor quality. I returned one for my s6 a Commuter because one of the sides the rubber was warped, and loose. I bought a Note 4 Defender and it was so poorly made you wouldn't even get the plastic to clamp together all the way. The Defender for the S6 I had was great, and the one I bought for my Note 5 is ok.
However Otterbox holds a monopoly it seems over Android cases on the market. If you want something as rugged you have to order online now.
I like the Poetic Revolution series cases. The one for my s6 was great and way cheaper than Otterbox and better.
Their QC does suck a big one. I have 3 commuter cases, The one made in the USA seems the be the best fit & finish. The china & Mexico ones have loose rubber and smooth insides where the USA model has an nice textured inside of the silicone. Whenever possible get the USA version.
Do you have a link to the Tumi case?
Got my Poetic Affinity case sent to me to review. I have been using a Verus Crystal Clear bumper case. I am liking the Affinity case much better. It's really slim. For a case that has this much protection itbhas a very slim profile. I like that the top and bottom have a softer material. This helps with finger fatigue.(not sure if that a thing but feels like it) The Verus case is sharp toward the bottom but the Affinity has a nice soft touch feel. The back maintains the curve and sides have great grip. All cutouts fit my 3rd party cables and Monster DNA in ears just fine. This is a good option for someone looking for a slim protective case.
Sent from my Note 5
Weird, but my Verus Army Green case doesn't seem to be made as well as my Red one.
The square bit covering the speaker, seems to move out of position often. I never noticed this with my Red one...
I also received the Poetic Affinity case to review. I like it much better than the Verus I have. Mine is clear and I like the feel of it. The case covers the power and volume buttons and they're not hard to press at all. The case isn't bulky at all. It keeps the slim profile of the Note 5. Here are some photos:View attachment 201060View attachment 201061View attachment 201062
