Just to set your expectations, this case is one of my favorites...but it is not without its shortcomings...
1) It's super thin...which is good...but also bad... Count on this case to protect your phone from scratches, but it won't provide much (if any) drop protection.
2) Some say it is a fingerprint magnet... Not sure I agree... It does have a matte finish, and as a result, a little bit of greasy fingers will place some undesirable fingerprints on the case...but I would not say that it is a fingerprint magnet like the naked glass case... At least not to the same degree....
3) There isn't much of a lip for screen protection... If you have no screen protector, I believe there is a little bit of a lip (like a 0.7mm lip). But if you put a 0.4mm protector on the screen, the gap gets reduced down to next to nothing... So while it does do a good job of protecting the non-screen casing from scratches, there is really minimal screen protection.
If you go in with the above expectations in mind (and you are okay with these limitations), I think you will really enjoy the minimal size and bulk of this case...
At this point, I have about 8-10 cases that I swap between depending on my mood... I go to this case a lot, given the super thinness of the case...
