04-25-2017 07:16 AM
3,351 ... 99100101102103 ...
tools
  1. MedicD's Avatar
    Thanks!... I already knew I had like 1 bar, but good to know just how awful it is. It's nice to see where the towers are though... they're on the other side of a 1000ft hill
    Attached Thumbnails Note 5 Battery life thread-1447471424463.jpg ย  Note 5 Battery life thread-1447471432352.jpg ย
    11-13-2015 09:24 PM
  2. jmj227's Avatar
    No I don't have a drone, or the freeflight app. And that's all I could find on google. Could it be google "play games" app?
    11-13-2015 09:26 PM
  3. MedicD's Avatar
    Possibly. Check what you recently installed
    11-13-2015 09:58 PM
  4. Ruben Ocasio's Avatar
    Outstanding ๐Ÿ‘๐Ÿ‘๐Ÿ‘
    11-14-2015 05:13 AM
  5. javitolopez's Avatar
    as you get it?
    is there a setting for the signal
    11-14-2015 05:27 AM
  6. Ruben Ocasio's Avatar
    as you get it?
    No settings , just got bloatware disable from AT&T and Material dark theme i am running my phone normal.
    javitolopez likes this.
    11-14-2015 05:30 AM
  7. s6edge's Avatar
    You also have to stop looking at "in this particular 5 mins I lost x% of battery" because you can't look at your battery life in that kind of increment and get a true picture. You have to look at the time period from fully charged and removed from the charger until it is low enough to charge again.
    That could be 3 days, that could be 7 days, that could be 10 hours, that could be 5 hours. You have to look at the 100%. Sometimes you will do something on your phone and it will drop 2% in 3 minutes and then sometimes you will do something on your phone and it will take over an hours for it to drop 2%.
    Here you go.. i took off my battery from charger and used it for like one hour i took some pictures after that...
    And used my phone the rest of the day just to call and most of time it was unused..
    The thing i noticed is it looses battery even if i dont use it.. i mean like in hour its looses 1% (can it be due to career)
    These days im busy with exams coming close so i dont use phone much.. but when exams are over it'll be a hard time with battery drain
    Also i took this screen at 8:17p.m so you guys think this is normal?
    Then i will have to charge the phone twice a day
    Also actually i would have used my phone only 2 and half hours active.. but im off to 34% from 100%
    I also noticed my phone chargers up in 1:15min... its supposed to take 1:30right.. is it a problem?
    About the screen shots : some are from after one hour of use. And rest is at 8pm odd
    Attached Thumbnails Note 5 Battery life thread-1447512645985.jpg ย  Note 5 Battery life thread-1447512673448.jpg ย  Note 5 Battery life thread-1447512692548.jpg ย  Note 5 Battery life thread-1447512714819.jpg ย  Note 5 Battery life thread-1447512734478.jpg ย
    11-14-2015 08:53 AM
  8. vdeng's Avatar
    Need some help with my Note 5. My battery drains like crazy. The first month I was using it, however, this was not an issue.
    11-14-2015 12:06 PM
  9. vdeng's Avatar
    I'm not getting this kind of performance!
    11-14-2015 12:52 PM
  10. MedicD's Avatar
    As everyone has pointed out, this thread you are in is for the NOTE 5, not the S6 EDGE. Regardless, your battery life is fine. 1% per hour would mean you could go 3 days with light use. Your photo at 36% remaining after that long during the day and 4 HOURS OF SCREEN TIME means you would be looking at over 6 hours use in about a 16 hour day. That's good.
    As for the note about an iphone... even my friends iPhone 6 plus drained that fast, so switching back to iPhone won't help you. Only thing that would is switch to the s6 Active.
    Kelly Kearns likes this.
    11-14-2015 02:39 PM
  11. kj11's Avatar
    I think we're done here. Please stop.
    11-14-2015 06:20 PM
  12. bettercallsal92's Avatar
    Can it be due to my carier ?
    I dont have a good signal most of the time..
    You're literally answering your own questions about battery drain. I have no idea why you're carrying on asking for help when you know what the problem is
    11-15-2015 12:06 PM
  13. hoofbeats95's Avatar
    Hi all. I'm new here. I have 3 lines of service on Sprint. Just upgraded all three to S6 phones. I'm appalled at battery life. So I was researching the note 5. It seems to consistently get better battery? I don't quite get what the GSam Battery Monitor screen shots are telling me. How do you read that data? Thanks!
    11-15-2015 03:09 PM
  14. MedicD's Avatar
    GSAM tells you what is using up how much of your battery. The note 5 is more efficient than the Galaxy S6 and has a bigger battery, so battery life is much better, yes. If you are able, I would recommend sending those back and getting the Note 5 or S6 edge+. I have the note 5 and my wife the edge +, her battery seems better than mine
    11-15-2015 07:20 PM
  15. Ruben Ocasio's Avatar
    Gotta say i am very happy with my battery life on my Note 5
    11-15-2015 10:33 PM
  16. hoofbeats95's Avatar
    What do you do to get this battery life? For example on my S6 I have lots of things turned off and power save mode turned on. Are you tweaking the phone like that? Or can I expect this battery life with the note 5 without doing all that stuff?
    11-16-2015 08:10 PM
  17. Ruben Ocasio's Avatar
    All i got on my AT&T Note 5 is bloatware disable and Enhanced 4G LTE services turned off and location set to mobile and wifi no tweaks at all and no not rooted either since AT&T Note 5 is locked down.
    11-16-2015 08:17 PM
  18. hoofbeats95's Avatar
    Thanks! I have Sprint and I wonder if I can expect similar results. This S6 battery life is a drag.
    11-16-2015 08:23 PM
  19. NatalieB2015's Avatar
    Make sure you turn off printing it comes on by default go to few post back i posted it cause that will also eat your battery if on.
    Running On Samsung Galaxy Note 5 N920A
    Thanks. I didn't know about this battery eater.
    11-16-2015 08:31 PM
  20. jmj227's Avatar
    After a lot of google searching, it turns out it was firefox that had a bug that kept the process "mdnsd" running continually. Uninstalled firefox and now it's fine.
    11-17-2015 06:39 AM
  21. hoofbeats95's Avatar
    MedicD - have you done alot to get good battery out of your note 5? Looking back through this thread it doesn't seem like you were happy with it. I eeked out about 3 hours of sot time over about 16 hours up time on my S6 yesterday. Not horrible but I found I was refraining from using it. And of course running in power save, disabled a lot of stuff and blah blah blah. . . . I literally squeaked that battery life out.
    11-17-2015 06:55 AM
  22. MedicD's Avatar
    My battery has sucked, but I think it's because I have bad signal everywhere in the mountains, and Verizon seems to have some issues too. Kelly on Tmob gets great battery though, so do most people.
    I also refuse to turn several things off, like Google Now
    11-17-2015 07:44 AM
  23. hoofbeats95's Avatar
    Thanks. I have Sprint. I don't think my phone reaches for signal much. I'm in the flatlands here in in IL. I did see that you lived in the mountains so I was wondering about that. Why does Verizon have issues? With just this phone? I've pondered returning all the S6 phones to Best Buy and switching to Verizon for the moto turbo 2. I've only ever had Sprint from my very first cell phone though. So that makes me nervous.
    11-17-2015 07:52 AM
  24. MedicD's Avatar
    Verizon seems to have the best signal most places. If you live in a city it sounds like Tmob is the best option (assuming you don't travel much). The mountains give everyone issues and Verizon still seems to be the best. I can't even find a radio station that will stay in tune my entire 15 minute commute.
    I'm a little jealous of that new shatterproof Droid, either the Force 2 or Turbo 2... can't remember which is better
    11-19-2015 11:49 PM
  25. hoofbeats95's Avatar
    T-mobile isn't so hot in my area. We can't really decide what to do. I'm one of the odd people that like Samsung's Touch Wiz I guess. . . . I haven't really had any other smartphone (the HTC hero long ago, but I barely remember it). So I'm nervous to switch to Motorola. . . But gosh this S6 just doesn't last as long as I'd expect from a new phone. I haven't taken any of them back (for the note 5 potentially) because we were considering the swap to Verizon. So I only wanted to return once. And I also have only known Sprint (17+ years) so to go to Verizon and Motorola is all out of my comfort zone. I'm pretty cranky with Samsung though and this crap battery life. And I'm just not sure I can "trust" that the note 5 will get enough to make it worth doing the exchange
    11-20-2015 07:48 AM
  1. Note 5 vs Note 4 discussion
    By NoNoiPhone4me in forum Phone Wars
    Last Post: 09-10-2015, 07:53 PM
  2. Will the Note 4 get the newer Note 5 software features?
    By ahhChu in forum Samsung Galaxy Note 4
    Last Post: 08-21-2015, 11:12 AM
  3. 5.1.1 Battery Life
    By PsychDoc in forum Samsung Galaxy S6
    Last Post: 08-17-2015, 03:18 PM
  4. Note 5/S6 Edge+ Expandable Cases
    Last Post: 08-14-2015, 09:07 PM
