04-25-2017 07:16 AM
3,351 ... 102103104105106 ...
tools
  1. ALSLZ0159's Avatar
    My battery drained 28% percent overnight (phone was at 79% last night). My screen brighntess is low and have Wifi tirn off when going to bed. Android OS stay awake is at 10hrs right now.
    Attachment 207776
    Attachment 207777
    11-30-2015 09:28 AM
  2. JJ Jones's Avatar
    It could be GSam causing the drain for those who are getting poor battery performance. According to play store reviews, many are having drain issues.
    From my Platinum Gold Note 5
    11-30-2015 10:06 AM
  3. rpoli86's Avatar
    Is it normal to wake up, take phone off charger (no apps open), get showered and dressed (maybe 25 min) go downstairs to car and be down to 95% already?
    Battery drain has been a big issue for me, I did a factory reset 3 weeks ago, didn't help.
    11-30-2015 10:35 AM
  4. ALSLZ0159's Avatar
    My phone drops to 96% after about an hour. After 2 hours it drops to 90%. I dont even use the phone. Really hope marshallow fixes this stand by drain.
    11-30-2015 10:39 AM
  5. Ruben Ocasio's Avatar
    Not normal, i go to work and after 2 hrs stays at 100% after 2hrs then it drops 1% a few minutes later.
    11-30-2015 10:48 AM
  6. hoofbeats95's Avatar
    I'd be all up on this phone if I could guarantee your battery life. I've been watching this thread cause I returned three S6 phones, and I just don't know if I feel confident in the note 5 battery life. I'm jealous of 2 hours at 100%!
    11-30-2015 10:52 AM
  7. vag74's Avatar
    For you with battery drain,install package disabler pro from store and freeze all samsung and google bloatware.
    11-30-2015 10:53 AM
  8. Ruben Ocasio's Avatar
    Look for some of my post go back a bit you will see how amazing battery life i have on my Note 5 AT&T
    11-30-2015 10:55 AM
  9. hoofbeats95's Avatar
    I've seen your battery life. I'm on sprint. Not sure it's carrier dependent. But it's the people that have drain that make me second guess the phone.
    11-30-2015 11:05 AM
  10. ALSLZ0159's Avatar
    I have tmobile. My battery drain is bad.
    11-30-2015 11:09 AM
  11. rpoli86's Avatar
    My phone was at 100% when I walked in the office an hour ago...I've opening FB once for a second. I'm down to 91% on WIFI wtf??? I dont get it, what can I do to fix this?
    11-30-2015 11:15 AM
  12. linkiik121's Avatar
    As I posted before gsam was giving me battery drain. After removing the phone battery is great. Just like the other posters I can be at 100% for 2 hours.
    You need to check the apps your using to see if they're causing the battery drain.
    Posted via Note 5 64GB AT&T
    11-30-2015 01:34 PM
  13. Ruben Ocasio's Avatar
    Attachment 207798Click image for larger version.
    I never used GSam heard it's a battery killer by lots in XDA, so i never had to use that app.
    11-30-2015 01:53 PM
  14. linkiik121's Avatar
    Good choice you don't need it and it does impact battery life.
    You also have very good battery life like me and very little drain.
    On a side note how it's your reception?
    I have AT&T as you do and my signal is almost always low three bars max and I thankfully I still have good battery life. Curious, what the battery life would be like if I had 5 bars or is that even possible on AT&T LTE.
    Ruben Ocasio likes this.
    11-30-2015 02:05 PM
  15. Ruben Ocasio's Avatar
    At home i get 3 to 4 bars, out in town or work i get all 5 bars and at home I'm always on wifi never had any network issues so all is great.
    11-30-2015 02:22 PM
  16. Ruben Ocasio's Avatar
    I am at work now i use my 4G LTE and look all 5 bars are up , and i work 10 hours a day
    11-30-2015 02:26 PM
  17. linkiik121's Avatar
    https://uploads.tapatalk-cdn.com/201...b3bab34cf9.jpg
    Hmmm, I'm in NYC and the only time I see 5 bars is when it's not really on LTE. I realized this when I did a speed test and my speed is faster at 3 bars than 5. So I downloaded an app call LTE discovery and it shows that the LTE sign is on but the 5 bars are coming from GSM. That explained the lower speed.
    I guess Wyoming is a better state for att
    11-30-2015 02:48 PM
  18. TheMatrix31's Avatar
    Does Gsam really have that much of an impact? Today's stats show me at Gsam only using 0.2 percent. Would that be reflected in the Android System percentage at all?
    The discrepancy in on-screen time in the pics I posted a few posts ago from yesterday must be from a restart because my on-screen time today in Gsam and in the main battery stats are basically the same. 47 minutes or so and I'm at 60 percent battery left after being off the charger for about 10.5 hours. Not bad hours-wise but again, barely any screen time or not nearly as much as everyone else's stats lend me to believe I should be getting.
    12-01-2015 12:26 AM
  19. linkiik121's Avatar
    Yes, gsam did have a very bad impact on my battery.
    As for the battery life your getting it is very bad for the Note 5. You need to disable everything and see how the battery life is without any apps draining.
    Then comes the question on the reception your getting? That would cause a big drain.
    Ruben Ocasio and recDNA like this.
    12-01-2015 01:55 AM
  20. TheMatrix31's Avatar
    As for the battery life your getting is very bad for the Note 5. You need to disable everything and see how the battery life is without any apps draining.
    Interesting. I have Package Disabler and have most things disabled. All the Knox stuff and ANT stuff, most of the extra Google stuff, too.
    Reception is good. Nothing amazing. 3-4 bars of 4g on Sprint when I'm at home with wifi. Only time reception might dip are on my drive to and from work. It's about a half hour drive.
    12-01-2015 03:26 AM
  21. JJ Jones's Avatar
    Maybe something you deactivated with Package Disabler is having a negative impact?
    I was at 6 hours SOT after 16 hours off charger yesterday before I hit 15% remaining.
    Took the boy to see Santa so I tossed it on the charger just to be sure I had more than enough juice for any photo ops that may come.
    12-01-2015 09:07 AM
  22. RC51 RIDER's Avatar
    I lose 1% every 3 hrs on my Note 5 on standby is that OK?
    Posted via the Android Central App RC51 RIDER W/ NOTE 5
    12-01-2015 09:08 AM
  23. Ruben Ocasio's Avatar
    Yes thats excellent standby.
    12-01-2015 09:11 AM
  24. Ruben Ocasio's Avatar
    Maybe if you add what you got deactivated might help him and what provider your phone is, just a thought.
    12-01-2015 09:12 AM
  25. James8561's Avatar
    What's ad guard? Seems to be taking up some battery.
    It's a system wide ad blocking program that filter through VPN. It's great! I never see any ads
    12-01-2015 02:59 PM
  1. Note 5 vs Note 4 discussion
    By NoNoiPhone4me in forum Phone Wars
    Last Post: 09-10-2015, 07:53 PM
  2. Will the Note 4 get the newer Note 5 software features?
    By ahhChu in forum Samsung Galaxy Note 4
    Last Post: 08-21-2015, 11:12 AM
  3. 5.1.1 Battery Life
    By PsychDoc in forum Samsung Galaxy S6
    Last Post: 08-17-2015, 03:18 PM
  4. Note 5/S6 Edge+ Expandable Cases
    Last Post: 08-14-2015, 09:07 PM
