04-25-2017 07:16 AM
3,351 ... 103104105106107 ...
tools
  1. JJ Jones's Avatar
    Today was my first "normal" day with the Note 5. Normal for me means getting up around 8 am, spending a little time on my phone, then heading into work around 120 pm. The main difference in my day is that since I work in a state prison, my phone sets in my car for 8.5 to 9 hours while I'm inside work. Very happy to report that I walked into work with 93% battery and still had 87% when I walked out, meaning a drain of only 6% for the 8.5 hours my phone set unused in my car.
    That's right in line with my Droid Turbo, which of course had a larger battery, so 6% drain on it was actually more mah lost than on the Note.
    From my Platinum Gold Note 5
    12-01-2015 10:05 PM
  2. zaayer's Avatar
    I updated the phone software yesterday (don't know the version number, but it was my 2nd update since I bought the phone about 3 weeks ago). The details said it brings "stability" and "security enhancements" to the phone. I decided to update because I have been having occasional strutting of the phone where it would hang for about 5-7 seconds and then be OK again. I thought it would fix it! Alas, not only did it not fix the hanging issue, it ruined my battery life!!
    Since the update, the battery life has been degraded a lot! Before I used to have a good 7 hours sleep with just 1-2% battery drain max, but now last night, it dropped 7% (from 100%) (almost 1% every hour without use!!!). Also, previously I had instances where after 1-2 hours of no use, I would have a 0% drop in battery life! Not anymore!
    While using the device, even after a minimal use of 5 minutes, the drain can be as much as 4%! I'm devastated by what Samsung have done with the update! I installed GSam to monitor battery. It shows the culprit as being "Android System" using about 25% of the battery.
    Any suggestions for me guys?
    P.S: I have the International Version of Note 5 - N920C
    12-01-2015 11:37 PM
  3. clevin's Avatar
    with each update, you may want to try clear the cache of the system and reboot it a few times.
    12-02-2015 05:42 AM
  4. linkiik121's Avatar
    This^
    Sometimes you need a factory reset to get everything to work right.
    Posted via Note 5 64GB AT&T
    12-02-2015 06:00 AM
  5. zaayer's Avatar
    But doesn't factory reset take you back to the original firmware the phone came with?
    Also, how do I "clear the system cache"? Will it result in loss of my data or will everything remain as is?
    12-02-2015 07:44 AM
  6. linkiik121's Avatar
    No factory reset does not take you back to the original firmware. But it does wipe the phone. Which is a pain to set everything back up again.
    Clearing system cache will not wipe your data. Everything will be the same.
    How to link:
    http://thedroidguy.com/2015/08/how-t...et-etc-1048204
    Ruben Ocasio likes this.
    12-02-2015 09:05 AM
  7. a1188323's Avatar
    Had it for a few days now, thinking about taking it back. Had a few nights of 30 percent drain on stand by. I think I sorted that out, as I had 4 last night, but it's still just not good. Most of these power breakdowns I see are dominated by screen..that's at the bottom of my list.
    2 pm on a very light use day and I'm at 55. By light use I mean maybe a half hour of screen time
    12-02-2015 01:12 PM
  8. linkiik121's Avatar
    Exchange it. I would... it should be working good out of the box.
    If my SOT time was half hour it would take me days to get to 55%.
    12-02-2015 01:58 PM
  9. robonik's Avatar
    The Note 5 is my first phone that doesn't have a user interchangeable battery. I tried the Note 4 first because I thought I absolutely had to have an interchangeable battery. However, after holding the Note 5 in my hand I decided to trade up during the return period. After all, my reasoning was that not once did I ever need to switch out the battery on my Galaxy S5.
    So far so good, the Note 5 seems very thrifty with the battery juice but just in case I picked up a power bank to keep handy. It features the Qualcom Fast Charging Technology so if I do have to top off the battery quickly I can do so. It looks like I won't need the power bank though other than for peace of mind.
    The Note 5 is at least as good with the battery usage as the Galaxy S5 after almost 2 months of heavy usage.
    12-02-2015 04:03 PM
  10. hoofbeats95's Avatar
    Yes. It installed all the apps I had on my note 4. It's crazy that its this much better than the s6. Really didn't buy any of the efficiency and optimization stuff at all. But something is working.
    Gosh! The S6 is awful. Loved the phone. Hated the battery. It's so bad I wish they'd roll out the S7 asap. I need a new phone badly.
    12-02-2015 09:40 PM
  11. TheMatrix31's Avatar
    Maybe something you deactivated with Package Disabler is having a negative impact?
    I was at 6 hours SOT after 16 hours off charger yesterday before I hit 15% remaining.
    Took the boy to see Santa so I tossed it on the charger just to be sure I had more than enough juice for any photo ops that may come.
    This is what I have disabled at the moment:
    I also tried using Swiftkey without vibration today but that didn't seem to have much of an impact either way.
    12-03-2015 01:59 AM
  12. vm81's Avatar
    Can you share what's disabled on your phone if anything? Also any specific settings we should keep in mind.
    12-03-2015 07:13 AM
  13. JJ Jones's Avatar
    Here you go:
    Attached Thumbnails Note 5 Battery life thread-screenshot_2015-12-03-10-18-08.jpg
    Rusky Santoso likes this.
    12-03-2015 09:19 AM
  14. recDNA's Avatar
    What was your trick to cure stand by bug? That alone is a major accomplishment.
    12-03-2015 09:22 AM
  15. a1188323's Avatar
    Package disabler and greenify. After doing that, it's much better.
    I also did a clearing of the cache last night and turned on advanced calling. The cell standby isn't at the top of my list today, but I'm not convinced the battery is any better.. right now at 1.5 hours sot and at 44%. That is letting it sit idle all night though
    12-03-2015 03:12 PM
  16. linkiik121's Avatar
    1.5 hour SOT with 44% and I don't care if the phone sat idle for 24 hours is terrible. I would get another phone if I got battery life like that. You most likely won't fix it and shouldn't have to. I don't have any power saving modes. Dont Dim my screen, use any power apps or package disabler and my phone battery is getting about 5 hours SOT and off the charger for 24 hours and have a remaining 38% battery..
    Samsung did a very good job with the battery on this phone. You need to exchange your phone for another one that works correctly. Or sell it and buy another one.
    recDNA likes this.
    12-03-2015 03:48 PM
  17. Ruben Ocasio's Avatar
    Wow that's really bad you should go and see to exchange your phone for another at 1.5 SOT i usually am at 75 to 78 %
    12-03-2015 04:58 PM
  18. a1188323's Avatar
    So..went to Verizon today to try and exchange and they wouldn't do it. They insisted that my battery numbers were "above average" after they ran their diagnostic tests. Wtf.
    They also said "you shouldn't believe everything you read on the internet" and that I the gsam battery app was damaging my battery. . Idiots.
    12-04-2015 05:57 PM
  19. linkiik121's Avatar
    Wow... go to another store and tell them the phone is freezing and you did a reset and that didn't do and you want to exchange it for a working one.
    12-04-2015 06:22 PM
  20. Ruben Ocasio's Avatar
    I would call instead make some stuff up so they can sent you another.
    12-04-2015 06:23 PM
  21. kj11's Avatar
    I don't know that fraud is the best solution....
    12-05-2015 05:56 AM
  22. MRBULLRED's Avatar
    This is my avg day.
    12-05-2015 09:06 AM
  23. MRBULLRED's Avatar
    Pic2
    12-05-2015 09:07 AM
  24. Ed the Head's Avatar
    Hello,
    I've had a similar problem. Started using the Note 5 last week and the battery has gone from bad to almost defunct. Recharging it is now pretty much impossible and I'm obviously going to send it back. As I'm from UK, I had to get the phone from Ebay and it may be the Hong Kong version. I've ordered a new one from US and hope it works. Are you aware of many people having issues? The model is 9200
    12-06-2015 07:31 AM
  25. Ruben Ocasio's Avatar
    Pic2
    Verizon bug, only AT&T and T-Mobile don't have theses battery life issues.
    12-07-2015 08:03 AM
  1. Note 5 vs Note 4 discussion
    By NoNoiPhone4me in forum Phone Wars
    Last Post: 09-10-2015, 07:53 PM
  2. Will the Note 4 get the newer Note 5 software features?
    By ahhChu in forum Samsung Galaxy Note 4
    Last Post: 08-21-2015, 11:12 AM
  3. 5.1.1 Battery Life
    By PsychDoc in forum Samsung Galaxy S6
    Last Post: 08-17-2015, 03:18 PM
  4. Note 5/S6 Edge+ Expandable Cases
    Last Post: 08-14-2015, 09:07 PM
