04-25-2017 07:16 AM
3,351 ... 104105106107108 ...
tools
  1. hoofbeats95's Avatar
    Verizon bug, only AT&T and T-Mobile don't have theses battery life issues.
    What about Sprint?
    12-07-2015 08:05 AM
  2. Ruben Ocasio's Avatar
    What about Sprint?
    Oh not sure about Sprint , only read this on websites about Verizon bug battery life issue, so I'm guessing Sprint might be ok unless i missed something .
    12-07-2015 08:06 AM
  3. Frookster's Avatar
    Haha. It won't. Confirmed on my friend's Note 5. Already showing wear and nothing he can do about it (sealed back). Down to 8 hours a day until fully drained, if lucky. Now he is fully turning the phone off during slow times of the day, just so he has power to make it home and recharge fully.
    12-07-2015 09:51 AM
  4. odb9014's Avatar
    My replacement Note 5 - 21:45 on a full charge with 5:15 SOT. Could have got 7+ hours of SOT easily with less idle time or 2 days idle with less SOT. Seems to be on par with my original Note 5.
    Sounds good to me.
    12-07-2015 03:38 PM
  5. isagreg's Avatar
    Got new Note 5 (Verizon), coming from Note 3.
    Battery life is BAD when WiFi is on and connected.
    Went from 100% to 25% overnight when the phone was idling ("cell standby" used 35% of battery)
    With WiFi off it drains from 100% to 95% overnight, just like my old Note 3.
    I really like the phone but basically forced not to use WiFi, or else gotta charge 2 times a day.
    Is there a fix?
    Thanks
    12-07-2015 04:06 PM
  6. Ruben Ocasio's Avatar
    Is there a fix?
    Thanks
    All i know it's a Verizon bug you will have to wait for them to fix that.
    12-07-2015 04:10 PM
  7. linkiik121's Avatar
    Showing wear? You do realize that 8 hours a until fully drained isn't wear. That is a defective battery. Sealed back does not mean you can't change the battery. It's just harder to do and not on the fly thing. Not to mention he can probably get it fix under warranty because his device is in fact a manufacturers defect.
    Besides that saying it's "already showing wear" is just plain ignorant. It's going to wear like every other phone battery. Like all things, if the phone battery is well-maintained, it will last longer than if drained to 0 everyday. Now even if the phone is drained every day the battery won't really show wear worth noting until over a year.
    Posted via Note 5 64GB AT&T
    12-07-2015 04:22 PM
  8. linkiik121's Avatar
    This^
    I heard not all people from Verizon are having this problem. You can try to exchange it and hope you get lucky with one that doesn't have this issue. Othet then that you'll have to wait for Verizon to fix it.
    12-07-2015 04:28 PM
  9. isagreg's Avatar
    Yea, I'm seeing there are complaints here since June, if it hasn't been fixed in 6 months do you think they'll fix it in the future?
    When you contact VZ customer support they start with usual BS like: "let's go to safe mode" or "let's check the background processes that might drain your battery" or the usual "reset to factory defaults". And as people mentioned nothing helps with that
    12-07-2015 06:03 PM
  10. linkiik121's Avatar
    Yes, I'm sure they will fix it. Remember marshmallow is on its way to the note 5.
    12-07-2015 06:44 PM
  11. isagreg's Avatar
    So the only hope is Marshmallow? Lollipop won't be fixed?
    Supposedly Note 5 will get Marshmallow sometimes in December 2015. But I doubt that.
    In the meantime I gotta keep my phone with WiFi off...
    Ridiculous...
    12-07-2015 06:54 PM
  12. JJ Jones's Avatar
    Ridiculous...
    If it's fixed in M, why should they waste time finding a temporary solution until M is released?
    From my Platinum Gold Note 5
    12-07-2015 07:52 PM
  13. david818's Avatar
    guys is this ok battery life??? i had it fully charged at 7am this morning with one hour of rocket player and one hour of spotify. the rest of the day it was idle. it keeps loosing 1% now its at 65 with no use..
    Attached Thumbnails Note 5 Battery life thread-screenshot_2015-12-07-21-51-44.jpg
    12-07-2015 10:04 PM
  14. vm81's Avatar
    Is there a fix?
    Thanks
    I had this issue for the longest time where I was losing 6-8% every hour overnight on standby. On average i was losing less than 1% every hour on LTE...everything else being equal. I didn't use WiFi for the longest time. It was same on mine and my wife's Note 5.
    Then Verizon sent update for Samsung Pay and other improvements... That essentially fixed it... Did a better job on my phone than my wife's but definitely made a huge difference. Now maybe I will lose 12-15% on 8 hours overnight on WiFi vs 5-6% on LTE.
    I still think they need to improve it further but at least it's usable now.
    12-07-2015 10:09 PM
  15. MedicD's Avatar
    Yes that's pretty good battery life
    12-08-2015 12:22 AM
  16. MedicD's Avatar
    I'm a vzw guy with wifi drain. Unfortunately it seems Colorado doesn't have very good 4g. I'm locked into unlimited so idc about data use, but without wifi I get horrible signal and no data.
    I noticed that in airplane mode with wifi on the drain isn't bad. I think that'll be what I stick to once wifi calling comes out
    12-08-2015 12:23 AM
  17. vm81's Avatar
    I am not one bit surprised that its better when its only on WiFi...this bug seems to kill battery only when BOTH LTE and WiFi are on at the same time.
    12-08-2015 09:04 AM
  18. rpoli86's Avatar
    here's a question....does WIFI drain the battery more than LTE?
    because I'm in work, and my I took my phone off charge at 100%...10 minutes later its down to 98%..I haven't done anything, nothing is open...the battery life lately has been HORRID.
    I reinstalled OS 3 days ago as well.
    12-09-2015 09:19 AM
  19. Beagles329's Avatar
    I would tend to say yes. I've been running a LTE only test since my last charge. While at home I have 2-3 signal bars and while at work I only have 1-2 signal bars. I'm on Verizon BTW.
    Below are my results.
    Note 5 Battery life thread-uploadfromtaptalk1449675129125.jpgNote 5 Battery life thread-uploadfromtaptalk1449675142083.jpg
    12-09-2015 09:32 AM
  20. Ruben Ocasio's Avatar
    All depends on how strong Wifi is and LTE can go either way it's all about the signal. Every where you go signals are different.
    12-09-2015 10:04 AM
  21. MedicD's Avatar
    Where I live I am lucky to get 1 bar lte, so wifi will definitely be better for me
    12-09-2015 10:23 AM
  22. linkiik121's Avatar
    That's not good. Is it just a bad area for cell service or just your carrier?
    12-09-2015 11:37 AM
  23. Ed the Head's Avatar
    I wrote about having bought a Note 5 recently with terrible battery life. I've just received another one from a different seller and it's the same. I'm pretty sure the first one originated from Hong Kong and the second from USA. Both are giving me about 2 hours' screen time before game over. The phones were bought unlocked and not attached to a network. There must be a general problem.
    12-09-2015 03:14 PM
  24. linkiik121's Avatar
    As general problem with what?
    Two hour screen time is nothing for a note 5. This is about 2 hours SOT and 12 hours off charger and 79%.
    12-09-2015 06:31 PM
  25. linkiik121's Avatar
    12-09-2015 06:32 PM
  1. Note 5 vs Note 4 discussion
    By NoNoiPhone4me in forum Phone Wars
    Last Post: 09-10-2015, 07:53 PM
  2. Will the Note 4 get the newer Note 5 software features?
    By ahhChu in forum Samsung Galaxy Note 4
    Last Post: 08-21-2015, 11:12 AM
  3. 5.1.1 Battery Life
    By PsychDoc in forum Samsung Galaxy S6
    Last Post: 08-17-2015, 03:18 PM
  4. Note 5/S6 Edge+ Expandable Cases
    Last Post: 08-14-2015, 09:07 PM
