04-25-2017 07:16 AM
3,351 ... 106107108109110 ...
tools
  1. guacapoli's Avatar
    I downloaded GSAM.
    My android system shows 20.8%
    kernel (android os) 1.5%
    system UI 8.3%.
    are these normal levels?
    12-14-2015 01:38 PM
  2. linkiik121's Avatar
    I downloaded GSAM.
    system UI 8.3%.
    Yes, look pretty normal to me.
    Posted via Note 5 64GB AT&T
    12-14-2015 06:40 PM
  3. linkiik121's Avatar
    Looks like I'm back to normal battery life. Not really sure what that was. I gave in did a factory reset and voila 6+ hours of screen time again. Hoping it lasts.
    12-14-2015 10:24 PM
  4. robonik's Avatar
    Looks like I'm back to normal battery life. Not really sure what that was. I gave in did a factory reset and voila 6+ hours of screen time again. Hoping is lasts.
    Good job! I know what you mean... my T-Mobile Note 5 is producing normal battery life most of the time but occasionally, something seems to get screwy and drain it somewhat faster but it hasn't been objectionable even in the worst case.
    12-15-2015 12:16 AM
  5. Rdsantos's Avatar
    Hello, I buy the note 5 duos
    Do I need battery from 8 am until 11pm.
    My rgular use is:
    4G always on
    Always-on synchronization
    push email
    3 hours internet during the day to check news, and email forums Tapatalk
    1 hour calls
    What do you think?
    And too tight?
    12-15-2015 06:56 AM
  6. Note5User's Avatar
    I have recently updated my home wifi router and connecting my Note 5 to 5GHZ band. I can see a lot of improvement now.
    It drains around 1% / hr. Earlier it is around 5%/hr.
    12-15-2015 04:07 PM
  7. aspiller1998's Avatar
    I have done everything possible, or so it seems. FDR multiple times, disabled bloat, and other apps to try to find the issue and nothing. Android OS and Android System drain my battery, along with gpsd, even though GPS is off... My battery was great when I had my phone for a few months, then two weeks ago it's been horrible.. Screen was always #1 on the battery stats, but not anymore. Like I said earlier, not even multiple FDR's fixed it. Here are the stats: http://imgur.com/a/c5MyA
    12-16-2015 02:49 PM
  8. robonik's Avatar
    T-Mobile put out an OTA update this morning. Before the update at 7:00am my battery was at 94%. As always I had taken it off the wireless charger before going to bed (last night at 10:15PM). Needless to say 6% drain overnight was excellent, actually better than my Galaxy S5's battery performance. So I then did the OTA update, charged it fully again, finishing the charge at 8:10AM. Between 8:10AM and 12:50PM it went down to 95%. Granted I only made 5 calls of about 3 minutes each average. I had no Internet or other usage besides the calls.
    This is the best battery performance I've had to date with any of my Samsung devices.
    12-16-2015 03:04 PM
  9. bmbriefs's Avatar
    Note 5 Battery life thread-uploadfromtaptalk1450404061548.jpgNote 5 Battery life thread-uploadfromtaptalk1450404069580.jpg
    I've had my note for about a week. Battery life started great, got worse. I'm getting less than 2 hours screen on time with fairly light usage. Android system and wifi are draining a ton. Any suggestions?
    12-17-2015 08:03 PM
  10. guacapoli's Avatar
    I've been having the same problem. Ill send a few texts and go down 5% in minutes.
    I chatted with AT&T customer support, explained my battery issues, they literally mailed me a replacement note 5 within an hour. I didn't even mention getting a replacement so it makes me wonder if there is a problem. I've never had a carrier so willingly replace a device. I am supposed to get it today. We shall see if battery is improved.
    12-18-2015 07:27 AM
  11. anon(9228075)'s Avatar
    On Verizon and since update a few days ago mines worse.
    Last night when went to bed it was 64% at 11:30. Woke up 7 am and it was 46%
    18% drain over 7 and half hours. I turned off advanced calling before bed to test if that helped. Guess not since usually I didn't lose that much overnight. Usually would lose 4 to 6% overnight. Crazy.
    I've got WiFi set to turn off when asleep btw.
    12-18-2015 07:29 AM
  12. vm81's Avatar
    Mine was great already but generally been even better since the Verizon update.
    Last battery cycle - 43 hours on battery with 4 hours 25 minutes SOT. This time around it looks like it will be around 6 hours SOT with 24 hours or so on battery
    12-18-2015 10:36 AM
  13. anon(9228075)'s Avatar
    Do you just use the battery app on the phone or do you use another app to determine screen time or other drain?
    12-18-2015 10:39 AM
  14. vm81's Avatar
    I just use phone in built monitor. Dont have GSAM or anything...I tend to avoid extra apps if I dont need them.
    hub1 likes this.
    12-18-2015 10:42 AM
  15. maskedcarrot's Avatar
    I have an AT&T and a Verizon Note 5. Recently my AT&T Note 5's battery life has gotten really bad.
    With light usage I usually in the past can get maybe 3 days out of a charge. Now I am getting just over a day. Nothing really changed recently.
    My Verizon model still gets good battery life. So there is either something with my AT&T Note's hardware, or maybe just a software glitch, but I am leaning more towards the hardware.
    I really hate to call AT&T and get a refurbished replacement for my 1 1/2 month old Note 5.
    This is why I really hate having a phone with a non-removable battery. I would much rather just get a new battery than have to replace the whole phone.
    12-18-2015 09:49 PM
  16. linkiik121's Avatar
    My at&t note 5 battery started to get bad as well. A factory reset fixed that.
    12-18-2015 10:15 PM
  17. maskedcarrot's Avatar
    I did a factory reset today and set up the phone from scratch. And I am also running down the battery to 0 to re-calibrate it.
    We'll see what happens.
    12-18-2015 11:30 PM
  18. sangs's Avatar
    Looks like I need to try a factory reset on my T-Mobile Note 5. Went from 100 to 90 overnight (11 p.m. to 5:30 a.m.). That is unacceptable. By comparison, my iPhone stayed at 100 during the same time frame.
    12-19-2015 08:46 AM
  19. vm81's Avatar
    Another beautiful battery cycle on Verizon Note 5 - 39 hours on battery with 5 hours SOT.
    I am always on LTE (not the best signal, but not bad). I know battery on WiFi is worse...but havent tried it recently. It used to be horrendous on WiFi but they fixed that after an update - so its more inline but still worse than LTE. My theory is that I am going to keep using Verizon data (LTE) - unless they fix the battery drain on WiFi
    12-19-2015 09:34 AM
  20. anon(9228075)'s Avatar
    What is the best settings to max battery on Verizon to help with cell standby?
    WiFi settings: is best to leave always on or set to on during sleep plugged in only, etc.
    Advanced calling: to have HD voice on but not video or both on or neither on?
    Any other settings to tweak?
    12-19-2015 09:45 AM
  21. maskedcarrot's Avatar
    So I started today with both my Verizon and AT&T Note 5s fully charged to 100% and turned on around 10am. It is now 10:24pm.
    My Verizon Note is at 59%, and my AT&T Note is at 56%.
    Nether phone was used all that much today being as I worked all day. My AT&T only has a 35 minute screen on time which was barely used to mainly just check Facebook a few times and check the news. So basically extremely light usage today.
    My Verizon Note has 1 hr 9 min screen on time and about the same type of usage, except maybe 20 minutes of watching Hulu at lunch.
    I just don't get it. This phone has a 3000 mah battery and gets really crappy battery life. When I still had my iPhone 6 plus, and with the same light usage I am talking about above, I could easily get 3 days battery out of the 6 plus.
    I don't get how the 6 plus get such better battery life than the Note 5.
    12-19-2015 09:37 PM
  22. anon(9228075)'s Avatar
    Tried an experiment last night. Since we have problems with cell standby drain on WiFi on verizon, I thought I'd just turn off WiFi when I went to bed and then turn back on this morning and see if that helped. Nada..
    Went from 55% to 38% over 7 hours.
    12-20-2015 01:25 PM
  23. robonik's Avatar
    Have installed the recent OTA update? T-Mobile here, went to bed after a full charge, 7 hours of standby while I slept, with WiFi, GPS, Bluetooth (connects to my home Panasonic cordless phones to provide an extra line to my landline hookup) and woke up with 95% my best battery performance yet.
    Granted, the first two Note 5's I received from T-Mobile were plagued by poor battery consumption performance and most importantly to me at the time the Bluetooth issue (my Plantronics headset would not stay connected). However, those 2 units didn't have the benefit of 3 OTA updates at least one of which had some fixes for the battery consumption.
    I don't know if it's a hardware or software issue that makes the difference. I am just grateful I finally got a copy that has neither a Bluetooth or battery issue.
    12-20-2015 02:31 PM
  24. maskedcarrot's Avatar
    So have you received your replacement? I was wondering if you were getting better battery life with the replacement?
    I am about to throw mine out the window. Battery life is horrible on my AT&T Note 5.
    12-20-2015 05:24 PM
  25. maskedcarrot's Avatar
    I found this youtube video with a few things to try. You can skip to 2:20 on the video to get to the important part.
    There are two main things he mentioned to turn off. Google location history, and Android Device Manager, which is under Device Administrators.
    I just turned them two off and am going to monitor it. If still no good results, then I'm going to call AT&T for a replacement. I just hate getting a refurb for my two month old phone.
    12-20-2015 06:31 PM
  1. Note 5 vs Note 4 discussion
    By NoNoiPhone4me in forum Phone Wars
    Last Post: 09-10-2015, 07:53 PM
  2. Will the Note 4 get the newer Note 5 software features?
    By ahhChu in forum Samsung Galaxy Note 4
    Last Post: 08-21-2015, 11:12 AM
  3. 5.1.1 Battery Life
    By PsychDoc in forum Samsung Galaxy S6
    Last Post: 08-17-2015, 03:18 PM
  4. Note 5/S6 Edge+ Expandable Cases
    Last Post: 08-14-2015, 09:07 PM
